'88 E30
Gonna get out tonight (hopefully) and get some por-15 on the subframes and trailing arms and diff.
Also gonna try and finish cleaning up under the car.
Still not sure what I should put on the struts/knuckles. I'll have to see how the por-15 goes on elsewhere. Although I'll be waiting to get coils welded up before anything goes on them
I'm looking forward to seeing the coil build.
Got my diff bushing today. I asked them to draw a trex brushing its teeth.
"Gangsta Rex don't got no long arms for his stank mouth"
I was not disappointed.
Also painting sway bars because I'm bored
Sways all dried and put in the trunk for now. Got the 1st coat of POR-15 on the front & rear subframe, rear trailing arms, subframe plates & lollipops. Will most likely put two more coats on everything eventually (still need to do the opposite sides of them)
Got everything coated in por-15
I will be top coating it with some enamel to get some areas and for more protection
Pics or it didn't happen
This stuff is a pain in the ass and I'm glad I'm done
Next step is ordering parts
Looks good! My front subframe and other stuff will be getting this treatment soon. What's up with the coil overs?
Got the topcoats on all the stuff today. Went with a gloss enamel. Put a shit load on it. Also under coated my car, it probably won't dry correctly. Also took the rack "apart"
It looked dicked at first, but it was fine after I cleaned it up. Added some grease on the teeth, took the ps block off back off, drained the crap, added more crap, worked the rack back and forth to get the excess out then put the delete plate back on
Getting the struts ready for coils.
Also whoever put the inner tierods in hulk-moded them. Vice grips + hammer + swearing and they barely came off. Lock plates were all farked by whoever installed them. It sucked
Also aligned my door and fender so it didn't look all borked
Also found some evidence of assholes in an air box(not my vehicle)...After I found acorns in my glovebox and kick panel.
Set a bunch of traps and left out some coolant for them. I hate rodents
Diff cover is now a color
Son, I am disappoint.
Didnt mask the hardware, diff tag, or the vent tube
I could sand it off maybe. I didn't clean up the hardware so it's not going to stick well anyways.
Couldn't read the diff tag either
Oh
And it'll be under the car
So
Eat
Shit
Snap
Isn't that way more work than taping it off in the first place? [emoji14]
Compared to taping off individual bolts a vent tube and a diff tag?
What was the oem color the bolts should be?
#showseason2018
Grab some SS bolts to replace them and done!
Good idea, but i don't care to buy bolts when the ones in there now work fine
Got all the bushings in
That's pretty much it
Found out I'll need to move the union a tad
well it happened, ordered about $1650 worth of crap tonight for it. (will get about $160 back in core)
Still remaining to buy:
coil overs
brake pads & fluid (still on the fence about pads)
front stainless brake lines
