  4. '88 E30
'88 E30
savebigmoney
    Got my diff bushing today. I asked them to draw a trex brushing its teeth. 0fbadc988fc02e198d0fbb4734d09968.jpg
    "Gangsta Rex don't got no long arms for his stank mouth"
    I was not disappointed.
    Also painting sway bars because I'm bored
      Sways all dried and put in the trunk for now. Got the 1st coat of POR-15 on the front & rear subframe, rear trailing arms, subframe plates & lollipops. Will most likely put two more coats on everything eventually (still need to do the opposite sides of them)
        Got everything coated in por-15
        I will be top coating it with some enamel to get some areas and for more protection
        Pics or it didn't happen
        This stuff is a pain in the ass and I'm glad I'm done
        Next step is ordering parts
        • CMartC
          CMartC
          CMart
          Brush or spray?
          Excursion 7.3
          E30 LS1
            CMart said:
            Brush or spray?
            Foam brushes
            I'll be top coating it with an enamel spray as well
              Looks good!  My front subframe and other stuff will be getting this treatment soon.  What's up with the coil overs?
                Got the topcoats on all the stuff today. Went with a gloss enamel. Put a shit load on it. Also under coated my car, it probably won't dry correctly. Also took the rack "apart"
                It looked dicked at first, but it was fine after I cleaned it up. Added some grease on the teeth, took the ps block off back off, drained the crap, added more crap, worked the rack back and forth to get the excess out then put the delete plate back on ff812ae590c0ff9ca26f581a2e84a55e.jpgf0b4a459eb82928980bb7597ecf2edfa.jpg51e5458720b7c1ecc1abce04a62c82e1.jpg784147839311a06df4edd5219264b31e.jpg
                Getting the struts ready for coils.
                Also whoever put the inner tierods in hulk-moded them. Vice grips + hammer + swearing and they barely came off. Lock plates were all farked by whoever installed them. It sucked
                Also aligned my door and fender so it didn't look all borked
                Also found some evidence of assholes in an air box(not my vehicle)...After I found acorns in my glovebox and kick panel.
                Set a bunch of traps and left out some coolant for them. I hate rodents
                  Diff cover is now a color
                    Son, I am disappoint.
                    Didnt mask the hardware, diff tag, or the vent tube
                    Good luck getting "Best In Show" this year
                      I could sand it off maybe. I didn't clean up the hardware so it's not going to stick well anyways.
                      Couldn't read the diff tag either
                      Oh
                      And it'll be under the car
                      So
                      Eat
                      Shit
                      Snap
                        Isn't that way more work than taping it off in the first place? [emoji14]
                          Compared to taping off individual bolts a vent tube and a diff tag?
                          What was the oem color the bolts should be?
                          #showseason2018
                            Grab some SS bolts to replace them and done!
                              Good idea, but i don't care to buy bolts when the ones in there now work fine
                                "Why buy new when slightly used will do?"
                                Unmasked bolts are like unfolded side mirrors during proper winter storage mode.
                                You should always mask your bolt
                                  Got all the bushings in
                                  That's pretty much it
                                  Found out I'll need to move the union a tad
                                    well it happened, ordered about $1650 worth of crap tonight for it. (will get about $160 back in core)
                                    Still remaining to buy:
                                    coil overs
                                    brake pads & fluid (still on the fence about pads)
                                    front stainless brake lines
                                      What did you buy?
                                      • CMartC
                                        CMartC
                                        CMart
                                        coil overs
                                        Not sure if I asked/you answered, but any interest in my coilover setup or coilover/bbk setup
                                        Excursion 7.3
                                        E30 LS1
                                          coil overs
