  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
  • CMartC
    CMartC
    CMart
    I think so too, but it will be the only thing not black or red on the car.
    This also means I have to worry about suspension sooner that I was planning.
    Excursion 7.3
    E30 LS1
    • CMartC
      CMartC
      CMart
      Exhaust manifolds fitted. Downpipes next.
      Any thoughts on dual exhaust E30s? I have an idea in mind for what I want to do, but am afraid it won't look right.
      Excursion 7.3
      E30 LS1
      • CMartC
        CMartC
        CMart
        Excursion 7.3
        E30 LS1
          Those wheels look great on there. If you want to change the color of them, I would recommend plastidip since they look so immaculate=)
            Dual exhaust, lol.
            As long as the engine is a V or boxer then duals are acceptable.
              dual exhaust just doesnt look right on bmws of this vintage. its also not worth the extra cost or work over single: extra piping, two mufflers, extra cutting of the valance, more weight, etc etc.
              i'm going for a big single oval exhaust tip when I redo mine.
                I would just run dual lengths along the stock routing, I agree it would take some work to be "symmetric"
                • CMartC
                  CMartC
                  CMart
                  I will likely go with a single exhaust with an inline muffler and electronic cutout bypass for when I want it loud.
                  Excursion 7.3
                  E30 LS1
                    I second this!
                    • andyhundleyA
                      andyhundleyA
                      andyhundley
                      Those wheels are so dreamy! If you ever decide to sell them, Ill be your guy!
                      (BTW I actually test drove that red sedan that your wheels came off of in Detroit like 6 years ago. It was really clean then but it doesn't look so hot these days.)
                      • CMartC
                        CMartC
                        CMart
                        I couldn't find another set for sale. What's the going rate in 16X7.5s?
                        Excursion 7.3
                        E30 LS1
                          Depends on the condition. If theyre mint I would say around $1000
                          • CMartC
                            CMartC
                            CMart
                            Interesting. I don't think there is another set for sale in the states right now.
                            Excursion 7.3
                            E30 LS1
                              Maybe not right now but quick Google search shows random sets from the past couple years anywhere from $600-$1750.
                                I split the difference=)
                                • CMartC
                                  CMartC
                                  CMart
                                  I'm happy with them. And I don't plan on selling the car now with all the hours I have into it.
                                  Excursion 7.3
                                  E30 LS1
                                    Do you have another wheel setup for when you want to use your v8? Those look great for sure.
                                    Edit.
                                    • CMartC
                                      CMartC
                                      CMart
                                      Keeping my eye out for something 9" or wider for the rear, but I don't mind roasting some tires.
                                      Excursion 7.3
                                      E30 LS1
                                        You wont want anything wider than 8" unless you plan on super stiff suspension and fender work or widening. 225/235 is pretty much maxed out which fit great on 8". It's much better to do a stickier 235 than going to 255.
                                          You are on a 16 right?
                                          225/45/16 is about the biggest you can fit up front with a roll
                                          What are your wheel specs? Offsets etc.
                                          I am on 16x8 square, +20 with 225/45/16
