1991 318is M62B44 Build
I would just run dual lengths along the stock routing, I agree it would take some work to be "symmetric"
I second this!
Those wheels are so dreamy! If you ever decide to sell them, Ill be your guy!
(BTW I actually test drove that red sedan that your wheels came off of in Detroit like 6 years ago. It was really clean then but it doesn't look so hot these days.)
You wont want anything wider than 8" unless you plan on super stiff suspension and fender work or widening. 225/235 is pretty much maxed out which fit great on 8". It's much better to do a stickier 235 than going to 255.
You are on a 16 right?
225/45/16 is about the biggest you can fit up front with a roll
What are your wheel specs? Offsets etc.I am on 16x8 square, +20 with 225/45/16
From what I read, its hard to find ISO flares at parts stores to rent and when you can the dies are worn from improper/too much use.
I got that along with a cutter and bender.
I'll lend it out once I am done with it to anyone who needs it.
