  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.2k Views 1 Watching
  • CMartC
    CMartC
    CMart
    Welding my trans mount tomorrow, which means the motor and trans go in this weekend.
    In the mean time I started sorting through this mess.
    Anything special about the E30 brake lines? Will a normal brake line flare kit work?
    Excursion 7.3
    E30 LS1
      37 degree or bubble flare is what they are I believe.
        Bubble flares is what I was told by one of the old school techs. If you haven't done flares before good luck and hopefully they turn out. My suggestions would be to spend $$ on a good flare tool. I broke bits on doing lines on my old car and they ended up leaking too with a rental tool.
          No you cannot use a standard brake line tool.
          • CMartC
            CMartC
            CMart
            4x100 16x7.5 AC Schnitzers... Picking them up this weekend.
            Excursion 7.3
            E30 LS1
              Nice find!
              • CMartC
                CMartC
                CMart
                Thanks I think I got a pretty good deal on them.
                Thinking about going gloss black, but feel bad painting these...
                Excursion 7.3
                E30 LS1
                  Silver is the way to go=)
                  • CMartC
                    CMartC
                    CMart
                    I think so too, but it will be the only thing not black or red on the car.
                    This also means I have to worry about suspension sooner that I was planning.
                    Excursion 7.3
                    E30 LS1
                    • CMartC
                      CMartC
                      CMart
                      Exhaust manifolds fitted. Downpipes next.
                      Any thoughts on dual exhaust E30s? I have an idea in mind for what I want to do, but am afraid it won't look right.
                      Excursion 7.3
                      E30 LS1
                      • CMartC
                        CMartC
                        CMart
                        Excursion 7.3
                        E30 LS1
                          Those wheels look great on there. If you want to change the color of them, I would recommend plastidip since they look so immaculate=)
                            Dual exhaust, lol.
                            As long as the engine is a V or boxer then duals are acceptable.
                              dual exhaust just doesnt look right on bmws of this vintage. its also not worth the extra cost or work over single: extra piping, two mufflers, extra cutting of the valance, more weight, etc etc.
                              i'm going for a big single oval exhaust tip when I redo mine.
                                I would just run dual lengths along the stock routing, I agree it would take some work to be "symmetric"
                                • CMartC
                                  CMartC
                                  CMart
                                  I will likely go with a single exhaust with an inline muffler and electronic cutout bypass for when I want it loud.
                                  Excursion 7.3
                                  E30 LS1
                                    I second this!
                                    • andyhundleyA
                                      andyhundleyA
                                      andyhundley
                                      Those wheels are so dreamy! If you ever decide to sell them, Ill be your guy!
                                      (BTW I actually test drove that red sedan that your wheels came off of in Detroit like 6 years ago. It was really clean then but it doesn't look so hot these days.)
                                      • CMartC
                                        CMartC
                                        CMart
                                        I couldn't find another set for sale. What's the going rate in 16X7.5s?
                                        Excursion 7.3
                                        E30 LS1
                                          Depends on the condition. If theyre mint I would say around $1000
