  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
  • CMartC
    CMartC
    CMart
    I couldn't find another set for sale. What's the going rate in 16X7.5s?
    Excursion 7.3
    E30 LS1
      Depends on the condition. If theyre mint I would say around $1000
      • CMartC
        CMartC
        CMart
        Interesting. I don't think there is another set for sale in the states right now.
        Excursion 7.3
        E30 LS1
          Maybe not right now but quick Google search shows random sets from the past couple years anywhere from $600-$1750.
            I split the difference=)
            • CMartC
              CMartC
              CMart
              I'm happy with them. And I don't plan on selling the car now with all the hours I have into it.
              Excursion 7.3
              E30 LS1
                Do you have another wheel setup for when you want to use your v8? Those look great for sure.
                Edit.
                • CMartC
                  CMartC
                  CMart
                  Keeping my eye out for something 9" or wider for the rear, but I don't mind roasting some tires.
                  Excursion 7.3
                  E30 LS1
                    You wont want anything wider than 8" unless you plan on super stiff suspension and fender work or widening. 225/235 is pretty much maxed out which fit great on 8". It's much better to do a stickier 235 than going to 255.
                      You are on a 16 right?
                      225/45/16 is about the biggest you can fit up front with a roll
                      What are your wheel specs? Offsets etc.
                      I am on 16x8 square, +20 with 225/45/16
                      • CMartC
                        CMartC
                        CMart
                        The wheels I have on there now are 7.5 and it looks like I have a ton of room out back.
                        I agree though sticky > wide.
                        Excursion 7.3
                        E30 LS1
                        • CMartC
                          CMartC
                          CMart
                          16x7.5 et25
                          I only care about wide for the rear. Fronts are whatever.
                          In other news I ordered all my brake line stuff yesterday. Once the booster bracket gets made I get to have some brake line bending fun.
                          Excursion 7.3
                          E30 LS1
                            What did you get for a flaring tool? I will be needing one at some point.
                            Sent from my potato phone
                            • CMartC
                              CMartC
                              CMart
                              http://www.amazon.com/OTC-4504-Stinger-Bubble-Flaring/dp/B0015PMZMU/ref=sr_1_1?ie=UTF8&qid=1426778201&sr=8-1&keywords=iso+bubble
                              From what I read, its hard to find ISO flares at parts stores to rent and when you can the dies are worn from improper/too much use.
                              I got that along with a cutter and bender.
                              I'll lend it out once I am done with it to anyone who needs it.
                              Excursion 7.3
                              E30 LS1
                                That's pretty cheap, good find. Reviews look good.
                                • CMartC
                                  CMartC
                                  CMart
                                  Yeah with how much of a pain brake lines are I figured buying was cheaper than renting in the long run.
                                  Excursion 7.3
                                  E30 LS1
                                  • CMartC
                                    CMartC
                                    CMart
                                    Making some progress on the booster relocation and waiting on some aluminum parts to get back from my welder.
                                    Since I have not been able to find a good wiring diagram I have some general electronics questions.
                                    From what I am gathering I need to take the main relay and fuel pump relay from the E39. Would these be located on the body harness or engine harness? There are a relays on the body harness and I am hoping those are it.
                                    If they are fact are do I just need to tap into the E30 ignition wires so I can power them when I IG1, IG2, start, etc they are powered? Basically just wire them into the E30 key, and then into the fuel pump and the starter?
                                    Any good write ups on general engine swaps and electronics for this?
                                    Excursion 7.3
                                    E30 LS1
                                    • CMartC
                                      CMartC
                                      CMart
                                      Got the booster bracket back from the welder last week. Put in some hours this weekend and got the booster bracket mounted and all of the linkage setup. "Hardest part of the swap" is now done. Next comes what will be the hardest for me which is the wiring.
                                      Excursion 7.3
                                      E30 LS1
                                      • CMartC
                                        CMartC
                                        CMart
                                        Bad/boring picture, but...
                                        Excursion 7.3
                                        E30 LS1
                                          Yes! Then what,   exhaust?
