  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
    dual exhaust just doesnt look right on bmws of this vintage. its also not worth the extra cost or work over single: extra piping, two mufflers, extra cutting of the valance, more weight, etc etc.
    i'm going for a big single oval exhaust tip when I redo mine.
      I would just run dual lengths along the stock routing, I agree it would take some work to be "symmetric"
      • CMartC
        CMartC
        CMart
        I will likely go with a single exhaust with an inline muffler and electronic cutout bypass for when I want it loud.
        Excursion 7.3
        E30 LS1
          I second this!
          • andyhundleyA
            andyhundleyA
            andyhundley
            Those wheels are so dreamy! If you ever decide to sell them, Ill be your guy!
            (BTW I actually test drove that red sedan that your wheels came off of in Detroit like 6 years ago. It was really clean then but it doesn't look so hot these days.)
            • CMartC
              CMartC
              CMart
              I couldn't find another set for sale. What's the going rate in 16X7.5s?
              Excursion 7.3
              E30 LS1
                Depends on the condition. If theyre mint I would say around $1000
                • CMartC
                  CMartC
                  CMart
                  Interesting. I don't think there is another set for sale in the states right now.
                  Excursion 7.3
                  E30 LS1
                    Maybe not right now but quick Google search shows random sets from the past couple years anywhere from $600-$1750.
                      I split the difference=)
                      • CMartC
                        CMartC
                        CMart
                        I'm happy with them. And I don't plan on selling the car now with all the hours I have into it.
                        Excursion 7.3
                        E30 LS1
                          Do you have another wheel setup for when you want to use your v8? Those look great for sure.
                          Edit.
                          • CMartC
                            CMartC
                            CMart
                            Keeping my eye out for something 9" or wider for the rear, but I don't mind roasting some tires.
                            Excursion 7.3
                            E30 LS1
                              You wont want anything wider than 8" unless you plan on super stiff suspension and fender work or widening. 225/235 is pretty much maxed out which fit great on 8". It's much better to do a stickier 235 than going to 255.
                                You are on a 16 right?
                                225/45/16 is about the biggest you can fit up front with a roll
                                What are your wheel specs? Offsets etc.
                                I am on 16x8 square, +20 with 225/45/16
                                • CMartC
                                  CMartC
                                  CMart
                                  The wheels I have on there now are 7.5 and it looks like I have a ton of room out back.
                                  I agree though sticky > wide.
                                  Excursion 7.3
                                  E30 LS1
                                  • CMartC
                                    CMartC
                                    CMart
                                    16x7.5 et25
                                    I only care about wide for the rear. Fronts are whatever.
                                    In other news I ordered all my brake line stuff yesterday. Once the booster bracket gets made I get to have some brake line bending fun.
                                    Excursion 7.3
                                    E30 LS1
                                      What did you get for a flaring tool? I will be needing one at some point.
                                      Sent from my potato phone
                                      • CMartC
                                        CMartC
                                        CMart
                                        http://www.amazon.com/OTC-4504-Stinger-Bubble-Flaring/dp/B0015PMZMU/ref=sr_1_1?ie=UTF8&qid=1426778201&sr=8-1&keywords=iso+bubble
                                        From what I read, its hard to find ISO flares at parts stores to rent and when you can the dies are worn from improper/too much use.
                                        I got that along with a cutter and bender.
                                        I'll lend it out once I am done with it to anyone who needs it.
                                        Excursion 7.3
                                        E30 LS1
                                          That's pretty cheap, good find. Reviews look good.
