  4. ‘91 E30
‘91 E30
    Much more useful than a cigar lighter
    You don't smoke cubans in your E30?
      This may seem dumb but I finally found a usb charger that doesn’t look like a giant tumor with 6 bright LEDs sticking 8” off the console.
      I bought the exact same one a couple years ago for the same reasons. Still charges things. Since it only has one job, that's a win in my book.
        Road America was a lot of fun. Surface was slick like usual since the repave.
        raw: http://fvscc.com/results/2020_Summer/Event1_raw.htm
        class: http://www.fvscc.com/results/2020_Summer/Event1_fin.htm
        My fastest run:
        It was good seeing @AsparagusMike & @suspenceful out and about. Veggie mikes car sounds great as always and Spence’s ///m looks glorious
          My fastest run:
          Those pesky S2000s
            A dab of oversteer here and there. Did anyone spin?
              What rear end are you running?
              How close were you to using all of second on some of the straights?
                Yes there were lots of spins and 6 or 7 cars broke on course.  “self tech” due to the pandemic seems to be more hazardous for your health
                  3.25 with a ZF trans. Probably had another 700rpm to go before limiter is my guess
                    Shots from first event (USAIR) were posted.
                      Wow I'm surprised they did a self-tech. That seems sketchy...
                      Tire/wheel fitment is awesome, looks great!
                        Was nice seeing/talking to you there! Great driving as always. I have some work to do...
                        Do you know if there will be photos from this RA event?
                          Probably, I think Austin was at the event.
                          https://www.flickr.com/photos/99430171@N06/albums
                            Diff stuff is all in, next autox is the 28th. Hopefully finish it in time
                              ^dumbass me forgot about the orings/seals on the flanges so I ordered those as well
                                Also shots from RA were posted
                                  Started pulling the diff, which turned into pulling the axles because I observed some weathered boots, flung grease and the axle stub bolts were coated in watery axle grease. Luckily I have enough GKN/EMPI repair kits to replace/repack every boot. It’ll be nice to check this off the list, car is getting closer to 99.9% “done”.
                                  side note: cv grease sucks
                                      Both are rebuilt and ready to go in once the diff is finished. The drivers side was near death in terms of lack of grease/grease condition, so the timing of this couldn’t have been better. B72A8F06-D12C-4975-9825-5A9F0637193B.jpeg
                                        Should've waited till you were on the way back from the picnic to address this
                                          Got around to pulling the diff out.
                                          comes apart quickly. Thanks @B C for removing the grime from a previous life. 522CADF1-A3E7-41CE-B648-4A3230D92888.jpeg
                                          gutted, reassembly of the internals is exactly the opposite of disassembly, less replacing the spacer with a third friction disc & dog ear plate.
                                          also replaced these clips that retain the axle stubs. They came with with new seals for the output flanges so why not.
                                          ^engage safety squints for those
                                          slapped new o rings on the output flanges too for good measure. Need to find a drift/socket large enough and pop the shaft seals out and replace them as well.
                                          slapped the carrier back together with the new discs that’s where I left off for tonight. Once I get the seals in, it is ready to get slapped back into the case. Then I can start on replacing the pinion seal. Punched/marked so I don’t screw up the preload
                                          here are the worn out discs that gave up the ghost at 41ftlbs (breakaway tq)
