  4. ‘91 E30
‘91 E30
    Much more useful than a cigar lighter
      You don't smoke cubans in your E30?
        This may seem dumb but I finally found a usb charger that doesn’t look like a giant tumor with 6 bright LEDs sticking 8” off the console.
        I bought the exact same one a couple years ago for the same reasons. Still charges things. Since it only has one job, that's a win in my book.
          Road America was a lot of fun. Surface was slick like usual since the repave.
          raw: http://fvscc.com/results/2020_Summer/Event1_raw.htm
          class: http://www.fvscc.com/results/2020_Summer/Event1_fin.htm
          My fastest run:
          It was good seeing @AsparagusMike & @suspenceful out and about. Veggie mikes car sounds great as always and Spence’s ///m looks glorious
            My fastest run:
            Those pesky S2000s
              A dab of oversteer here and there. Did anyone spin?
                What rear end are you running?
                How close were you to using all of second on some of the straights?
                  Yes there were lots of spins and 6 or 7 cars broke on course.  “self tech” due to the pandemic seems to be more hazardous for your health
                    3.25 with a ZF trans. Probably had another 700rpm to go before limiter is my guess
                      Shots from first event (USAIR) were posted.
                        Wow I'm surprised they did a self-tech. That seems sketchy...
                        Tire/wheel fitment is awesome, looks great!
                          Was nice seeing/talking to you there! Great driving as always. I have some work to do...
                          Do you know if there will be photos from this RA event?
                            Probably, I think Austin was at the event.
                            https://www.flickr.com/photos/99430171@N06/albums
                              Diff stuff is all in, next autox is the 28th. Hopefully finish it in time
                                ^dumbass me forgot about the orings/seals on the flanges so I ordered those as well
                                  Also shots from RA were posted
                                    Started pulling the diff, which turned into pulling the axles because I observed some weathered boots, flung grease and the axle stub bolts were coated in watery axle grease. Luckily I have enough GKN/EMPI repair kits to replace/repack every boot. It’ll be nice to check this off the list, car is getting closer to 99.9% “done”.
                                    side note: cv grease sucks
                                        Both are rebuilt and ready to go in once the diff is finished. The drivers side was near death in terms of lack of grease/grease condition, so the timing of this couldn’t have been better. B72A8F06-D12C-4975-9825-5A9F0637193B.jpeg
                                          Should've waited till you were on the way back from the picnic to address this
