    Got some epoxy primer sprayed down on the rear valance to keep it from rusting and also give a protective base before body filler. Still have a few spots to grind/sand smooth too. Pretty close on the color just for fun. [emoji4]
    Also, ordered some goodies, but alas, my bad luck with shipping shows through again. Only 2 of the 4 were delivered. What the crap!?!
      Those tires look badass!
        MEATS! Nice, I cant wait to see the pair mounted 😒
        • JeffJ
          JeffJ
          Jeff
          1976 530i e12
          1990 325ix e30
          1992 325i e36
          1995 740il e38
          2001 330xi e46
          ^More to come :)
          • JeffJ
            JeffJ
            Jeff
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              Daggerty
              Jeff said:
                Daggerty said:
                Jeff said:
                    Hankook rs4! Very nice
                      I'm sure you already called, but tire rack usually has some pretty good customer service. I'm sure they'll get it sorted out
                        It was on UPS's side of things. Somewhere along the way UPS put them on separate trucks, so the last 2 tires showed up yesterday. Just glad I didn't have to deal with lost package BS. Time to get them mounted and balanced!
                        I also picked up the material from Speedy Metals to do the chassis diff mount work. Not looking forward to removing the undercoating or for welding upside down. But, you gotta do what ya gotta do.
                          Use a sharp, stiff putty knife. It will make less or a mess and actually work better than a wire wheel. You could use a pneumatic needle gun too=)
                            I was planning on trying my air chisel with a wide flat blade to hopefully shave it off in pieces instead of wire wheel dust.
                              Little progress everyday. Decided to use my multitool I had bought to cut a cabinet out to install a dishwasher in my tenants kitchen. Worked like a charm!
                                Tires be mounted!!!
                                  It would appear that the tire mounting process is: Toss some tires and wheels in Saabaru, set COBB AccessPort to BoxxerRumble Agitate mode, close hatch, wait 5 minutes.
                                    Don't tell!!! It's the secret of the ROO!
                                      Son of a bitch!!!! I got everything cut out and part of the mount fitted. I go to set the welder up and the wire feed speed controller does nothing. The welder only feeds at one speed no matter what you do to change it. I was aiming to have the mount done today. Anybody have any ideas why it's doing this?
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        What welder do you have?
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                          He is using JB-Kwik in the two small tubes and its spilling out faster than desired. The cap isnt actually a feed speed controller knob but I can understand the confusion.
                                          I prefer the JB putty because I have more control even though it sets up faster
