      Hankook rs4! Very nice
        I'm sure you already called, but tire rack usually has some pretty good customer service. I'm sure they'll get it sorted out
          It was on UPS's side of things. Somewhere along the way UPS put them on separate trucks, so the last 2 tires showed up yesterday. Just glad I didn't have to deal with lost package BS. Time to get them mounted and balanced!
          I also picked up the material from Speedy Metals to do the chassis diff mount work. Not looking forward to removing the undercoating or for welding upside down. But, you gotta do what ya gotta do.
            Use a sharp, stiff putty knife. It will make less or a mess and actually work better than a wire wheel. You could use a pneumatic needle gun too=)
              I was planning on trying my air chisel with a wide flat blade to hopefully shave it off in pieces instead of wire wheel dust.
                Little progress everyday. Decided to use my multitool I had bought to cut a cabinet out to install a dishwasher in my tenants kitchen. Worked like a charm!
                  Tires be mounted!!!
                    It would appear that the tire mounting process is: Toss some tires and wheels in Saabaru, set COBB AccessPort to BoxxerRumble Agitate mode, close hatch, wait 5 minutes.
                      Don't tell!!! It's the secret of the ROO!
                        Son of a bitch!!!! I got everything cut out and part of the mount fitted. I go to set the welder up and the wire feed speed controller does nothing. The welder only feeds at one speed no matter what you do to change it. I was aiming to have the mount done today. Anybody have any ideas why it's doing this?
                        • JeffJ
                          JeffJ
                          Jeff
                          What welder do you have?
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            He is using JB-Kwik in the two small tubes and its spilling out faster than desired. The cap isnt actually a feed speed controller knob but I can understand the confusion.
                            I prefer the JB putty because I have more control even though it sets up faster
                              If it's coming out slow make sure the tube to the gun isn't wrapped up you want it as straight as you can get it.
                              Warranty that shit.
                                It's coming out similar to about mid way of the speed settings. I checked the resistance of the speed dial and I get a variable resistance, so it can't be the dial itself. Gonna have to wait till tomorrow to call lincoln support. I've had this welder for years, no warranty left here.
                                  Grow a third arm and check power and ground while using it.
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    What Lincoln welder do you have?
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      Got a good amount of work done this weekend. Got a new welder a few weeks ago, cut the old structure out under car, welded in new metal to strengthen it back up, made dual diff hanger mojts, welded them in, painted it all up and got the subframe/diff torqued down.
                                        Going to push for the picnic?
                                          Trying to, but won't be rushing anything either. That's when mistakes happen and I don't want to have to do something AGAIN just because I rushed.
