    Subframe and diff are temporarily (possibly permanently depending on if they're in the way or not) installed, thanks as always to Brian's help! Ran into a few snags, mostly being the stock diff mount had to be cut out for the diff to fully seat. Got that done. Looks like I'll need to do some slicing and dicing to the frame brace. Diff hangers are already touching that brace and don't want any vibration problems.
    Plan of attack is sectioning the frame where the mounts need to be and boxing it all back in once the new hangers are welded. Welding/boxing it all in will give the rigidity back to the structure. Oh how I wish I had a lift to make this a lot easier. Sigh!
      Got some epoxy primer sprayed down on the rear valance to keep it from rusting and also give a protective base before body filler. Still have a few spots to grind/sand smooth too. Pretty close on the color just for fun. [emoji4]
      Also, ordered some goodies, but alas, my bad luck with shipping shows through again. Only 2 of the 4 were delivered. What the crap!?!
        Those tires look badass!
          MEATS! Nice, I cant wait to see the pair mounted 😒
          • JeffJ
            JeffJ
            Jeff
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
            • JeffJ
              JeffJ
              Jeff
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                Jeff said:
                  Daggerty said:
                  Jeff said:
                      Hankook rs4! Very nice
                        I'm sure you already called, but tire rack usually has some pretty good customer service. I'm sure they'll get it sorted out
                          It was on UPS's side of things. Somewhere along the way UPS put them on separate trucks, so the last 2 tires showed up yesterday. Just glad I didn't have to deal with lost package BS. Time to get them mounted and balanced!
                          I also picked up the material from Speedy Metals to do the chassis diff mount work. Not looking forward to removing the undercoating or for welding upside down. But, you gotta do what ya gotta do.
                            Use a sharp, stiff putty knife. It will make less or a mess and actually work better than a wire wheel. You could use a pneumatic needle gun too=)
                              I was planning on trying my air chisel with a wide flat blade to hopefully shave it off in pieces instead of wire wheel dust.
                                Little progress everyday. Decided to use my multitool I had bought to cut a cabinet out to install a dishwasher in my tenants kitchen. Worked like a charm!
                                  Tires be mounted!!!
                                    It would appear that the tire mounting process is: Toss some tires and wheels in Saabaru, set COBB AccessPort to BoxxerRumble Agitate mode, close hatch, wait 5 minutes.
                                      Don't tell!!! It's the secret of the ROO!
                                        Son of a bitch!!!! I got everything cut out and part of the mount fitted. I go to set the welder up and the wire feed speed controller does nothing. The welder only feeds at one speed no matter what you do to change it. I was aiming to have the mount done today. Anybody have any ideas why it's doing this?
                                        • JeffJ
                                          JeffJ
                                          Jeff
                                          What welder do you have?
                                          1976 530i e12
                                          1990 325ix e30
                                          1992 325i e36
                                          1995 740il e38
                                          2001 330xi e46
                                          ^More to come :)
