  4. '88 E30
'88 E30
savebigmoney
    Good thing I have deep sockets, a big hammer and the right mental attitude regarding lock plates
      Capture.thumb.PNG.9018a0ea908b17bd2402fc
        Fuck this. I'm throwing them away. Just gonna tighten the shit out of it
        Lolololol
          ignore brian, he's on crack like i mentioned before.
          since when is real oem an accurate assembly guide? i suppose brian must have two stacked 5-lug front rotors on your e30 as shown in this diagram:
          • The Full BananaT
            The Full BananaT
            The Full Banana
            oof. checkmate.
            • i_love_carsI
              i_love_carsI
              i_love_cars
              Rofl @ rotors on top of rotors
              but it I mean I definitely agree with the strategy of using a hammer. I'm not sure a project is actually a project without using one.
              2007 Z4MR
              2003 E39 M5
              2002 E46 M3
              2021 X5 40i
                Found my axle nuts. In a box. Labeled. "Sway bar parts" guys I think I need to quit at things
                  Brian, my tuning pitchfork is currently resting in the garage.
                  I shall brandish my axle nut shovel for this discussion.
                  You are an engineer, and it saddens me that you are subscribing to the theory of the lock plate being used as a washer to ensure the nut doesn't rotate. In your assemblies do you not use lock nuts when you are doing sheet metal? Because the sheet metal would deform and capture the nut, in your theory.Though that depends on the type of metal used.
                  I could easily remove an axle nut with the lock plate behind it. But if you put it on the proper way (over the nut) you cannot even get a socket on it. That bad boy is locked in there.
                  #endrant
                    FWIW: mine were put on incorrectly by the PO. ("Washers" behind nut) I spun them off with an impact, bent tabs and all
                    • andyhundleyA
                      andyhundleyA
                      andyhundley
                      Shots fired!
                        Jet fuel cant bend properly installed lock plates.
                        I will procure further evidence of proper lock plate installation
                        • ClassEC
                          ClassEC
                          ClassE
                          Step 1: Install Nut (Torque to a gazillion ft/lbs)
                          Step 2: Place washer "over" nut aligning tabs
                          Step 3: Beat repeatedly until fully seated
                          DUN.
                            ^ agreed. To end this all, my compact rear wheel bearings were original and the locking plate was smashed on over the nut=)
                              To end this all check out my snap chat tech tips. Bring your own beer
                              Kaiser_rolls
                                You guys are correct. My memory sucks and I suck.
                                Back to my mound of cocaine....
                                  It's all put back together. Everything is torqued besides the axle nutzz
                                    It's okay sir. I shall now retire my shovel for further axle nut discussions.
                                    Seriously, whoever doesn't have Mr. Kaiser on snapchat is/was missing out. His series of "tech tips" was causing me to have uncontrollable laughter last night.
                                      ^made my night
                                        My favorite was the PB Blaster one=)
                                          lol
