'88 E30
Good thing I have deep sockets, a big hammer and the right mental attitude regarding lock plates
Fuck this. I'm throwing them away. Just gonna tighten the shit out of it
Lolololol
since when is real oem an accurate assembly guide? i suppose brian must have two stacked 5-lug front rotors on your e30 as shown in this diagram:
oof. checkmate.
Rofl @ rotors on top of rotors
but it I mean I definitely agree with the strategy of using a hammer. I'm not sure a project is actually a project without using one.
Found my axle nuts. In a box. Labeled. "Sway bar parts" guys I think I need to quit at things
Brian, my tuning pitchfork is currently resting in the garage.
I shall brandish my axle nut shovel for this discussion.You are an engineer, and it saddens me that you are subscribing to the theory of the lock plate being used as a washer to ensure the nut doesn't rotate. In your assemblies do you not use lock nuts when you are doing sheet metal? Because the sheet metal would deform and capture the nut, in your theory.Though that depends on the type of metal used.
I could easily remove an axle nut with the lock plate behind it. But if you put it on the proper way (over the nut) you cannot even get a socket on it. That bad boy is locked in there.
#endrant
FWIW: mine were put on incorrectly by the PO. ("Washers" behind nut) I spun them off with an impact, bent tabs and all
Shots fired!
To end this all check out my snap chat tech tips. Bring your own beer
Kaiser_rolls
It's all put back together. Everything is torqued besides the axle nutzz
You guys are correct. My memory sucks and I suck.
Back to my mound of cocaine....
It's okay sir. I shall now retire my shovel for further axle nut discussions.
Seriously, whoever doesn't have Mr. Kaiser on snapchat is/was missing out. His series of "tech tips" was causing me to have uncontrollable laughter last night.
lol
