  4. '88 E30
'88 E30
savebigmoney
  • The Full BananaT
    The Full BananaT
    The Full Banana
    since when is real oem an accurate assembly guide? i suppose brian must have two stacked 5-lug front rotors on your e30 as shown in this diagram:
    oof. checkmate.
    • i_love_carsI
      i_love_carsI
      i_love_cars
      Rofl @ rotors on top of rotors
      but it I mean I definitely agree with the strategy of using a hammer. I'm not sure a project is actually a project without using one.
      2007 Z4MR
      2003 E39 M5
      2002 E46 M3
      2021 X5 40i
        Found my axle nuts. In a box. Labeled. "Sway bar parts" guys I think I need to quit at things
          Brian, my tuning pitchfork is currently resting in the garage.
          I shall brandish my axle nut shovel for this discussion.
          You are an engineer, and it saddens me that you are subscribing to the theory of the lock plate being used as a washer to ensure the nut doesn't rotate. In your assemblies do you not use lock nuts when you are doing sheet metal? Because the sheet metal would deform and capture the nut, in your theory.Though that depends on the type of metal used.
          I could easily remove an axle nut with the lock plate behind it. But if you put it on the proper way (over the nut) you cannot even get a socket on it. That bad boy is locked in there.
          #endrant
            FWIW: mine were put on incorrectly by the PO. ("Washers" behind nut) I spun them off with an impact, bent tabs and all
            • andyhundleyA
              andyhundleyA
              andyhundley
              Shots fired!
                Jet fuel cant bend properly installed lock plates.
                I will procure further evidence of proper lock plate installation
                  Step 1: Install Nut (Torque to a gazillion ft/lbs)
                  Step 2: Place washer "over" nut aligning tabs
                  Step 3: Beat repeatedly until fully seated
                  DUN.
                    ^ agreed. To end this all, my compact rear wheel bearings were original and the locking plate was smashed on over the nut=)
                      To end this all check out my snap chat tech tips. Bring your own beer
                      Kaiser_rolls
                        You guys are correct. My memory sucks and I suck.
                        Back to my mound of cocaine....
                          It's all put back together. Everything is torqued besides the axle nutzz
                            It's okay sir. I shall now retire my shovel for further axle nut discussions.
                            Seriously, whoever doesn't have Mr. Kaiser on snapchat is/was missing out. His series of "tech tips" was causing me to have uncontrollable laughter last night.
                              ^made my night
                                My favorite was the PB Blaster one=)
                                  lol
                                    any way to get snap chat without a smart phone. 😒
                                      any way to get snap chat without a smart phone. <_>
                                      Tablet or iPod that can download apps
                                        That one and the one regarding finally giving up on tech tip numbers.
                                        .....and the spray cans on the shelf.
                                        ...and the one about keeping old hardware.
                                        Many of these hit home apparently lol.
                                          Got the subframe in & steering rack
                                          Subframe needed some persuasion
                                          Steering rack needed a tad of persuasion too. E36 rack/tierods
