  4. '88 E30
'88 E30
savebigmoney
    Whoever did mine did them wrong then. Because the lock plate was definitely behind the nut.
      I will gladly beat the shit out of them from pure frustration tonight
      Makes sense to put them on after to bend them to the shape of the hex though
        I have always done them under the axle nut like shown in the picture.
        As you tighten the axle nut  the lock plate crushes down and prevents the corners of the axle nut from rotating past them until you pry them open
        you are smoking crack that picture clearly shows the lock plate on top of the nut. how does a flat plate crush down? the back of the axle nut is round, not hex.
        you shouldnt be torquing your axle nuts down without the subframe installed and the weight of the car on the wheels/hub IIRC. i don't know if it would even be possible, they get torqued to 180ft/lbs or something, you will have to hold the axle somehow...
          Thanks for the info Dan. I guess I'll have to wait to beat the shit out of them
            I will fight this one to the death. it may have been 4 years ago but im pretty sure you Ben and Mitch are Bushelmasters
            • andyhundleyA
              andyhundleyA
              andyhundley
              Kaiser Rules Andy Drools
                Good thing I have deep sockets, a big hammer and the right mental attitude regarding lock plates
                  Capture.thumb.PNG.9018a0ea908b17bd2402fc
                    Fuck this. I'm throwing them away. Just gonna tighten the shit out of it
                    Lolololol
                      ignore brian, he's on crack like i mentioned before.
                      since when is real oem an accurate assembly guide? i suppose brian must have two stacked 5-lug front rotors on your e30 as shown in this diagram:
                      • The Full BananaT
                        The Full BananaT
                        The Full Banana
                        oof. checkmate.
                        • i_love_carsI
                          i_love_carsI
                          i_love_cars
                          Rofl @ rotors on top of rotors
                          but it I mean I definitely agree with the strategy of using a hammer. I'm not sure a project is actually a project without using one.
                          2007 Z4MR
                          2003 E39 M5
                          2002 E46 M3
                          2021 X5 40i
                            Found my axle nuts. In a box. Labeled. "Sway bar parts" guys I think I need to quit at things
                              Brian, my tuning pitchfork is currently resting in the garage.
                              I shall brandish my axle nut shovel for this discussion.
                              You are an engineer, and it saddens me that you are subscribing to the theory of the lock plate being used as a washer to ensure the nut doesn't rotate. In your assemblies do you not use lock nuts when you are doing sheet metal? Because the sheet metal would deform and capture the nut, in your theory.Though that depends on the type of metal used.
                              I could easily remove an axle nut with the lock plate behind it. But if you put it on the proper way (over the nut) you cannot even get a socket on it. That bad boy is locked in there.
                              #endrant
                                FWIW: mine were put on incorrectly by the PO. ("Washers" behind nut) I spun them off with an impact, bent tabs and all
                                • andyhundleyA
                                  andyhundleyA
                                  andyhundley
                                  Shots fired!
                                    Jet fuel cant bend properly installed lock plates.
                                    I will procure further evidence of proper lock plate installation
                                      Step 1: Install Nut (Torque to a gazillion ft/lbs)
                                      Step 2: Place washer "over" nut aligning tabs
                                      Step 3: Beat repeatedly until fully seated
                                      DUN.
                                        ^ agreed. To end this all, my compact rear wheel bearings were original and the locking plate was smashed on over the nut=)
                                          To end this all check out my snap chat tech tips. Bring your own beer
                                          Kaiser_rolls
