  4. '88 E30
'88 E30
savebigmoney
    FWIW: mine were put on incorrectly by the PO. ("Washers" behind nut) I spun them off with an impact, bent tabs and all
    • andyhundleyA
      andyhundleyA
      andyhundley
      Shots fired!
        Jet fuel cant bend properly installed lock plates.
        I will procure further evidence of proper lock plate installation
          Step 1: Install Nut (Torque to a gazillion ft/lbs)
          Step 2: Place washer "over" nut aligning tabs
          Step 3: Beat repeatedly until fully seated
          DUN.
            ^ agreed. To end this all, my compact rear wheel bearings were original and the locking plate was smashed on over the nut=)
              To end this all check out my snap chat tech tips. Bring your own beer
              Kaiser_rolls
                You guys are correct. My memory sucks and I suck.
                Back to my mound of cocaine....
                  It's all put back together. Everything is torqued besides the axle nutzz
                    It's okay sir. I shall now retire my shovel for further axle nut discussions.
                    Seriously, whoever doesn't have Mr. Kaiser on snapchat is/was missing out. His series of "tech tips" was causing me to have uncontrollable laughter last night.
                      ^made my night
                        My favorite was the PB Blaster one=)
                          lol
                            any way to get snap chat without a smart phone. 😒
                              any way to get snap chat without a smart phone. <_>
                              Tablet or iPod that can download apps
                                That one and the one regarding finally giving up on tech tip numbers.
                                .....and the spray cans on the shelf.
                                ...and the one about keeping old hardware.
                                Many of these hit home apparently lol.
                                  Got the subframe in & steering rack
                                  Subframe needed some persuasion
                                  Steering rack needed a tad of persuasion too. E36 rack/tierods
                                    Tomorrow I'll be taking the rear most subframe bolts out again so I can get the ST sway bar on. Also going to try and get the control arms on
                                      Sway bar is mounted and torqued
                                      Got the control arm offset bushings on (pain in the ass because of the taper)
                                      I'll most likely pop those in tomorrow. After they are in I'll be dropping the engine back onto the subframe so I can get the support bar out of the way. Then it'll be on to the rear subframe
                                      For anyone who was curious about the ST sway bar hardware here's a picture. Way beefier Than the oem stuff. Washer has a gap due to this shit being 28 years old
                                      Also does anyone have any use for these rear trailing arm sway bar mount reinforcements (and bushing brackets)?? I already had these reinforcements.
                                      If you pay postage they're yours
                                        Looking good!
                                        Smart move to mark the orientation on the lollipops before install on the control arms.
                                          It's official. I have no idea what to do for suspension. I can't make up my mind
