1.6k Posts 49 Posters 0 Views 1 Watching
    I like that idea!
    • i_love_carsI
      i_love_carsI
      i_love_cars
      This is fucking crazy. We may actually gain a net positive +2 running E30s in the group this season.
      2007 Z4MR
      2003 E39 M5
      2002 E46 M3
      2021 X5 40i
        Chipping away!  Got the trans and starter bolted up
        Next, laying out the wiring harness, steam vents, inake manifold then headers!  Gonna roll it under the car and lift it all into place.
          steam vents?!
          I installed my m52 from underneath. I think i like doing it that way better than ramming the engine hoist into the ceiling.
          Im guessing you are using a Sikky swap kit?
            steam vents?!
            It's an LS thing, you wouldn't understand.
              steam vents?!
              Implementing a turbosteamer system for maximum tire-roasting power
              https://www.drivingthenation.com/bmw-heat/
                This is where my mind went....
                Image result for exhaust heat car meme
                  steam vents?!
                  Sikky kit with their aluminum drive shaft and stainless 1 7/8" headers and other bits. Hopefully I can get some time in the garage this weekend.
                    I'm not sure if I do yet
                      Picked up new HD control arms, e46 ZHP steering rack, tie-rods, bushing for the treehouse control arm mounts and the CATuned coilovers should be back from getting welded up soon.
                        What does the e46 zhp rack solve that the z3 doesn’t?
                        also what rates did you go with?!
                          I believe the zhp rack is nearly as quick as the the z3 but doesn’t cost an arm and a leg, and is easier to find. They also came in some non zhp e46s as well. If I end up replacing the rack in my car when I do the lines this year, it’s probably what I’m going to get.
                            From my limited reading it is not as twitchy as the Z3 rack but still quick. I was looking for something that wasn't totally annoying to drive on the freeway for road trips.
                              Working on the steam vent routing on the 4 corners of the heads. This MSD intake is BIG.
                              PCV routing is next up on the to do list after the steam vents.
                              Anyone know of a good, low profile product to put in the trans tunnel for noise/heat shielding? Something with adhesive backing would be great.77008a6f47b84a009a2cc1de09edfc95.jpg7f176b6338464cf65de25b6bda4ff61a.jpgbcd38d799266ca6d7879977c38eb5d0b.jpgc9c8a815fd253224f462a213a114f891.jpg
                                Dynamat for your tunnel!
                                I enjoy your shiny things! Steam vents are still odd to me...
                                  https://www.designengineering.com/category/catalog/dei-cycle/insulating-materials/reflect-cool
                                  That DEI stuff works wonders. Used it on all the racecars at my old work.
                                    You can probably even get that stuff in gold
                                      Image result for MR.T gif
                                        Steam venting is complete!bae85c29299a858626fcaa44784c8491.jpg0364d9276fb5af61f3ae78a234e03393.jpg33029ec22f9629568bed52d5b3fb0c76.jpgef9e69a768f8ad6f00dedbaba309b06c.jpgc201a4611ce747ed38b2f89334a38611.jpg
                                          Also slid the motor a little closer to its final resting place.
                                          Scary stuff to have the front end that high up! 0728450c38e6be07ecced93623178c5c.jpga61531e46b177a1a1458c77b637d2ce9.jpg41462909e3efb7a2dd22af1c0ee71f57.jpgae3ce2224576bf78f65fd7b68ff0a0ec.jpg
