    steam vents?!
    Implementing a turbosteamer system for maximum tire-roasting power
    https://www.drivingthenation.com/bmw-heat/
      This is where my mind went....
      Image result for exhaust heat car meme
        steam vents?!
        I installed my m52 from underneath. I think i like doing it that way better than ramming the engine hoist into the ceiling.
        Im guessing you are using a Sikky swap kit?
        Sikky kit with their aluminum drive shaft and stainless 1 7/8" headers and other bits. Hopefully I can get some time in the garage this weekend.
          wasnt m3 said:
          It's an LS thing, you wouldn't understand.
          I'm not sure if I do yet
            Picked up new HD control arms, e46 ZHP steering rack, tie-rods, bushing for the treehouse control arm mounts and the CATuned coilovers should be back from getting welded up soon.
              What does the e46 zhp rack solve that the z3 doesn’t?
              also what rates did you go with?!
                I believe the zhp rack is nearly as quick as the the z3 but doesn’t cost an arm and a leg, and is easier to find. They also came in some non zhp e46s as well. If I end up replacing the rack in my car when I do the lines this year, it’s probably what I’m going to get.
                  From my limited reading it is not as twitchy as the Z3 rack but still quick. I was looking for something that wasn't totally annoying to drive on the freeway for road trips.
                    Working on the steam vent routing on the 4 corners of the heads. This MSD intake is BIG.
                    PCV routing is next up on the to do list after the steam vents.
                    Anyone know of a good, low profile product to put in the trans tunnel for noise/heat shielding? Something with adhesive backing would be great.77008a6f47b84a009a2cc1de09edfc95.jpg7f176b6338464cf65de25b6bda4ff61a.jpgbcd38d799266ca6d7879977c38eb5d0b.jpgc9c8a815fd253224f462a213a114f891.jpg
                      Dynamat for your tunnel!
                      I enjoy your shiny things! Steam vents are still odd to me...
                        https://www.designengineering.com/category/catalog/dei-cycle/insulating-materials/reflect-cool
                        That DEI stuff works wonders. Used it on all the racecars at my old work.
                          You can probably even get that stuff in gold
                            Image result for MR.T gif
                              Steam venting is complete!bae85c29299a858626fcaa44784c8491.jpg0364d9276fb5af61f3ae78a234e03393.jpg33029ec22f9629568bed52d5b3fb0c76.jpgef9e69a768f8ad6f00dedbaba309b06c.jpgc201a4611ce747ed38b2f89334a38611.jpg
                                Also slid the motor a little closer to its final resting place.
                                Scary stuff to have the front end that high up! 0728450c38e6be07ecced93623178c5c.jpga61531e46b177a1a1458c77b637d2ce9.jpg41462909e3efb7a2dd22af1c0ee71f57.jpgae3ce2224576bf78f65fd7b68ff0a0ec.jpg
                                  got my dose of engine porn for the day!
                                    Closer and closer!!
                                      That throttle body could swallow a kitten
                                        Im glad to see you are insulating the car from the cold during these freezing months
                                          Sent from my SM-G965U using Tapatalk
