1.6k Posts 49 Posters 0 Views 1 Watching
    Someone change this mans thread title!!
      Glad to see some updates!
        I've conformed to the LS world and lost all creativity. Suggestions?
          Buttoned up the fuel system!
          80-3888479195550bef7fd91bde32433cb61c
          80-38884789855c23917af9ebaaa2e2538aaf
          80-249137203575db2d9571bbc4b49e17690c
          80-2800540350973ebe0d67fbd073127871b6
            glad i'm not the only one who's frame rail looks disregarded :lol:
            those new lines are oh so tidy. *thumbsup
              I want to weld a 1/4" thick plate to my jack points so i dont feel as bad about things
              Looks good man! Does the LS require larger fuel lines? I can now gladly say that i have now seen one of those 135 degree bend AN fittings in use. Are the lines aluminum? I wouldnt think steel would be uncoated.
                Thanks!  This thing has been jacked up so many times...  LOL  a local indy shop smashed up my rockers after they were perfectly straightened out by yours truly.  Those will get bent back and painted.
                All the dents gives the jack something to grab onto!
                It doesn't require larger fuel lines.  I'm running 5/16 steel fuel lines for now.  Got the line in a 30' roll from napa.  We will see how they hold up but they should be fine.
                Two 120 degree AN fittings are looking great!  Behling Racing in Butler hooks it up for these things.  I broke one this AM while making the hose and they only charged me $10 for a new one.
                  Behling is my new Go-to instead of Pegasus (fast cars, slow service)
                  What about just spraying some clear spray paint on the lines? I am a rust-o-phobe.
                  You dont have to humor me, I just cry at bare metal
                    I like that idea!
                    • i_love_carsI
                      i_love_carsI
                      i_love_cars
                      This is fucking crazy. We may actually gain a net positive +2 running E30s in the group this season.
                      2007 Z4MR
                      2003 E39 M5
                      2002 E46 M3
                      2021 X5 40i
                        Chipping away!  Got the trans and starter bolted up
                        Next, laying out the wiring harness, steam vents, inake manifold then headers!  Gonna roll it under the car and lift it all into place.
                          steam vents?!
                          I installed my m52 from underneath. I think i like doing it that way better than ramming the engine hoist into the ceiling.
                          Im guessing you are using a Sikky swap kit?
                            steam vents?!
                            It's an LS thing, you wouldn't understand.
                              steam vents?!
                              Implementing a turbosteamer system for maximum tire-roasting power
                              https://www.drivingthenation.com/bmw-heat/
                                This is where my mind went....
                                Image result for exhaust heat car meme
                                  steam vents?!
                                  Sikky kit with their aluminum drive shaft and stainless 1 7/8" headers and other bits. Hopefully I can get some time in the garage this weekend.
                                    I'm not sure if I do yet
                                      Picked up new HD control arms, e46 ZHP steering rack, tie-rods, bushing for the treehouse control arm mounts and the CATuned coilovers should be back from getting welded up soon.
                                        What does the e46 zhp rack solve that the z3 doesn’t?
                                        also what rates did you go with?!
                                          I believe the zhp rack is nearly as quick as the the z3 but doesn’t cost an arm and a leg, and is easier to find. They also came in some non zhp e46s as well. If I end up replacing the rack in my car when I do the lines this year, it’s probably what I’m going to get.
