  4. Fancy Stancy 325is
Fancy Stancy 325is
pssshhhhhmy wife is goin
193 Posts 17 Posters 3.8k Views 1 Watching
    Thanks!
    I seem to be losing fuel at a rapid rate. 1/3 tank gone in 60 miles is not right.  I can't find a drip anywhere though.  I did check the vacuum line on the FPR and no gas in there.  Injector stuck open?  Wouldn't that cause it to run horrible?  It idles a little high but seems smooth and I just had the battery disconnected so it is still adapting.
    Check the gauge. Otherwise I would test all the injectors.
      10k miles on the car so far.  Runs like a champ except starting is a challenge below 0.  Monday morning I knew it was going to be really cold so I put it on ramps in the garage and put a pair of 250w chicken heat lamps under it.  Were block heaters or oil pan heaters ever available for the e36?
        Chicken heat lamps is a wonderful idea for that haha!
          Just buy a magnetic oil pan heater, I know they are available locally at Farm and Fleet.
            Aloominium
              Aloominium
              damn it! carry on...
                Also there are adhesive ones, but they would never stay on with the copious amount of oil that escapes confinement.
                  I saw a heated oil dipstick but it had a 1 star review
                    Curious how much of an improvement your rebuild of the shifter linkage did? I definitely am going to have to do that this summer on my car.
                      Huge improvement, a DSSR and new plastic cup are essential.  The delrin front carrier bushings and poly rear carrier bushing are nice.  Might as well do it all "while you are in there"  Get the Turner rear poly bushing that was linked earlier that is already installed in a bracket.  The garagistic one is a pain, not worth the savings.
                        Will do. I also plan on getting a z3 short shifter and a zhp knob.
                          Update on using the EV6 injectors, I finally got around to making some spacer rings to ensure that the injectors can't slip out of the fuel rail and cause a leak.  The original EV1 injectors had more plastic at the base so that even if you did not install the retaining clips the injectors can't go anywhere.  The clips mainly keep the injectors in the rail when you remove it.  The EV6 injectors I got could slip down enough to come out of the fuel rail if you pushed on them.  They also didn't have a groove for the clip, EV6 injector bodies are not all the same, some have enough plastic to cut new grooves for the retaining clips but these do not and they were the only thing I could find within 5% of the green injectors flow rating.  The are from a Ford Contour SVT.  You can see here how there is almost 1/4" before the plastic body would bottom out on the manifold, this picture is just from test fitting.
                          z9CPzIx.jpg?1
                          I made 6 rings to put over the injectors to mimic the stock design.  .531 ID, .210 length.  The OD was .730ish because I just skimmed some 3/4 stock.  304 stainless because that is what's in the scrap bin at work.
                          XVXqG6n.jpg?1
                          ttPpRd1.jpg?1
                          Installed.  There is a little wiggle room, around .010 - .015.  I feel much better about them now.
                          OC3iAyi.jpg?2
                          I also fixed the coil pack studs on cylinder 5 that were held in with JB weld which was not sufficient.  One was already pulled out and the other you could only tighten finger tight or it would pull out too.  i used helicoils which worked well.  Other than the magnesium shavings from drilling/tapping the manifold make a huge mess sticking in the oil residue that coats everything on this car.  I didn't get any pictures but you get the idea.
                          In other news something is going funky, my gas mileage dropped to horrendous levels.  Like 15mpg.  I verified that no injectors are leaking, no external fuel leaks.  A brand new Bosch FPR did not help.  I replaced the O2 sensor with Bosch within the last 10k but maybe it's junk?  or maybe I need to send the injectors out to get checked.  They were Ebay "Refurbished"  with 6 of them for 60 bucks so I was a bit skeptical.  They are genuine Bosch ones but were probably just pulled from a junk car.
                            Check the flow of them with a simple 9v battery outside of the car into a jar? Is the FPR adjustable? Get a gauge on there and you can see what the FP is at.
                              How much drive time do you have on the new injectors?
                              I have been getting 15 mpg in my DD when I normally get 18, just from the last few bitter cold weeks.
                              As for the clip grooves up top, I had a set that i dremelled some slots into
                                I've had them in for several thousand miles.  Maybe the extreme cold, it seems intermittently running rich.  I don't leave it idling to warm up more than a minute.  Some days it runs perfect and some days the idle hangs like it's getting too much fuel.  I usually get 24ish mpg though.  Also sometimes getting off of the highway I notice a burning smell but that might just be leaked oil burning on the cats...
                                The poor gas mileage started before I did this but I added some 2 stroke oil about 100:1 to a tank of gas when the cold was extreme and it helped starting, it must seal and have better compression with a little oil mixed in but that tank is gone now and been refilled.
                                These injectors are narrow at the top so you can't dremel grooves in them.
                                  Have you considered trying a new coolant temp sensor?
                                    After you mentioned the cold weather that crossed my mind, I will check the resistance and see.  I have another coolant temp sensor at home too.  The engine does seem to be running rich.  It does not pop when switching to deceleration like it normally does either.  The revs hang during a shift and are slow to drop when disengaging the clutch.  It is quite possible it thinks it needs to be enriching due to a cold engine.  I would think if the o2 was that bad I would get a CEL but maybe not.  This is where OBD2 would be a little nicer...
                                      Well I checked the resistance of the coolant temp sensor for the ECu and it seems fine, 330ish ohms when warmed up.  It appears to have gone back to normal now that the frigid temps have let up.  Also for the second round of cold weather I put a quart of 2 stroke oil in the gas and then filled up and it started just fine when previously it would not have.  So that's a plus.
                                      I need to replace the o-rings for the plugs on the back of the oil filter housing.  They are not available from BMW separately from the entire housing but someone on the internet says they are a 118 o-ring so i will order a pack of them in Viton material.
                                      We got a bunch of snow here today, super excited to drive home!
                                        Seems to have fixed itself when it isn't miserably cold out.  Getting excited for warm weather.  Thinking about tires for summer, I don't want to break the bank, reviews on Firestone Firehawk Indy 500 are excellent and it's only 93$ in 225/50R16.  https://www.tirerack.com/tires/tires.jsp?tireMake=Firestone&tireModel=Firehawk+Indy+500&sidewall=Blackwall&partnum=25WR6FHI5&tab=Sizes
                                        Thoughts?  I will just be ripping to work and back but I would like to try out something beyond all seasons.  I have the Wibimmers standard General Altimax Arctic for winter so cold weather is not a concern.
                                          I think joe runs those tires maybe he will chime in
