  4. E30 M52
E30 M52
    Cams removed, they didnt break. Now to achieve the same success installing the S52 cams.
    Probably Saturday
      The first time is the worst. So the story goes.
        Journals in good shape?
          Yeah, nothing to see there
            Ball
            Sacks
            Intake cam is in but while torquing the bearing caps to 15 Nm two of the studs pulled out
            I can only imagine the horror people feel as they torque head bolts into an aluminum block and feel it give way.
            Not the end of the world at all but I will have to remove the cam and trays/lifters to helicoil them.
            Minor annoyance. Not the progress I was hoping for today though
            • JeffJ
              JeffJ
              Jeff
              Ouch man what a kick in the nuts
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                1000x better than breaking a camshaft though. I'll take it.
                  Odd that the head-side went. You'd think the stud would be bottomed out and the nut wouldn't turn it anymore.
                  But as you said. 100000 times better than a cam
                  • JeffJ
                    JeffJ
                    Jeff
                    But see now your doubling your chances at breaking it so that would be -1000x. We both know that will just cancel it self out now and create the crazy looking number "0"
                    Practice makes perfect?
                    1976 530i e12
                    1990 325ix e30
                    1992 325i e36
                    1995 740il e38
                    2001 330xi e46
                    ^More to come :)
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      Helicoils are garbage. Get some keenserts from McMaster!
                      says the guy who had to use them too many times on his all aluminum engine. 😦
                        Times-sert is another option.
                        Don't have any experience with them, but my boss thinks they are great. Do have experience with heli-coils, mostly trying to fix ones that someone else has installed and have now failed. Not fun.
                          Being a low torque application I will stick with heli-coils. If it were head bolt threads in an aluminum block id definitely consider the timesert. Thanks for the mentions though
                          • The Full BananaT
                            The Full BananaT
                            The Full Banana
                            Good luck. If the helicoils give you trouble, keenserts (or timeserts) will be there for you. I had about 50% success rate with helicoils in the same application (aluminum head, low torque fasteners to secure the cams) before being shown the light by a friend.
                              Coolant pipe adapter installed. I went with the overpriced one from Turner rather than the overpriced one from Achillies or making my own. I like the fact that this kit comes with a popsicle stick and DOUBLE/BUBBLE brand 2 part epoxy.
                                +1 for using a time-serts, a much better option IMO. I would think you of all people would hate to do something a second or third time.
                                  I have 3 kids,  what are you trying to say here?!?!
                                  Gosh dang you guys and your Timesert recommendations after I have already committed to using a Helicoil
                                    LOL.  Time -to - insert, bad pun here.
                                    • JeffJ
                                      JeffJ
                                      Jeff
                                      +1 to Helicoil
                                      1976 530i e12
                                      1990 325ix e30
                                      1992 325i e36
                                      1995 740il e38
                                      2001 330xi e46
                                      ^More to come :)
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        Really I have used 1000's of these without issues on low torque applications. Just make sure the STI tapped hole is clear of chips before installing.
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                          Jeff got my back
