    Tires be mounted!!!
      It would appear that the tire mounting process is: Toss some tires and wheels in Saabaru, set COBB AccessPort to BoxxerRumble Agitate mode, close hatch, wait 5 minutes.
        Don't tell!!! It's the secret of the ROO!
          Son of a bitch!!!! I got everything cut out and part of the mount fitted. I go to set the welder up and the wire feed speed controller does nothing. The welder only feeds at one speed no matter what you do to change it. I was aiming to have the mount done today. Anybody have any ideas why it's doing this?
          • JeffJ
            JeffJ
            Jeff
            What welder do you have?
            1976 530i e12
            1990 325ix e30
            1992 325i e36
            1995 740il e38
            2001 330xi e46
            ^More to come :)
              He is using JB-Kwik in the two small tubes and its spilling out faster than desired. The cap isnt actually a feed speed controller knob but I can understand the confusion.
              I prefer the JB putty because I have more control even though it sets up faster
                If it's coming out slow make sure the tube to the gun isn't wrapped up you want it as straight as you can get it.
                Warranty that shit.
                  It's coming out similar to about mid way of the speed settings. I checked the resistance of the speed dial and I get a variable resistance, so it can't be the dial itself. Gonna have to wait till tomorrow to call lincoln support. I've had this welder for years, no warranty left here.
                    Grow a third arm and check power and ground while using it.
                    • JeffJ
                      JeffJ
                      Jeff
                      What Lincoln welder do you have?
                      1976 530i e12
                      1990 325ix e30
                      1992 325i e36
                      1995 740il e38
                      2001 330xi e46
                      ^More to come :)
                        Got a good amount of work done this weekend. Got a new welder a few weeks ago, cut the old structure out under car, welded in new metal to strengthen it back up, made dual diff hanger mojts, welded them in, painted it all up and got the subframe/diff torqued down.
                          Going to push for the picnic?
                            Trying to, but won't be rushing anything either. That's when mistakes happen and I don't want to have to do something AGAIN just because I rushed.
                              Have you gone back over the cooling system? That seems to be the part that always sabotages you coming places=/
                                There is still quite a bit I need to check over from previous "rush" jobs. I want to fix the exhaust leak at the manifold, fuel leak at the feed connection point, and definitely look to see how I can redo the lower hose routing. All this on top of finishing up the rear end. Then of course body work and group 2 kit install. Oh and I will need to see if I will have to redo the exhaust or not.
                                  In 4 Gruppe 2 kit!!!!!!
                                    Motorsport hardware studs installed in rear hubs. CV axle hardware cleaned and installed with a shit ton of locktite. Better not come out again. Rear rotors resurfaced and installed along with calipers. Rear brakes bled. And test fit of new wheels. Guess I didn't account for the negative camber when calculating fitment with flares. Will have to see what is needed after car is on ground.
                                    451ed5d330bfdd27080a3b555d000f4e.jpg675dba715c95a028ce7b679e292460c0.jpg9f184e92607635e33ee5936467a8241e.jpge12c21d7d7c1d7d544a5e24780d885a4.jpgafb65e90ecac15939f3ce50d80861b36.jpg8b11ced436ceb3105c12c4e4c144dd93.jpg45573f733c7b8805e92ba113a9ee952d.jpg
                                      That rear end looks insane. You need some 355s
                                        Throw some D's on it
                                          Yup, just what I thought. Kicking myself for not welding in some camber adjustments when the subframe was out. Also, still notbaure about that wheel gap with the flares. [emoji53] 02146a57d504e74a54055cbeeff7f412.jpg32c4f5a96ff59dbdeff5b50faf28b7d2.jpg9ae96c23e677ecff6a7f9aea5957a9d2.jpg25606363777e9254f4641704b55a98ab.jpg
