  4. The E46 M3 Journal
The E46 M3 Journal
e46m3
    If it rotates too easily that isn't good either.  I removed one that freely spun back and forth, it should feel like its rotating through heavy oil.  Best description I could think of this early.
      Swapped over the intake cam sensor. This one is a slight pain. Need to take off the vacuum tube and fuel rail/injectors.
      Turned my attention to the TPS sensors. Took the definitely working ones from the old motor and put them on the new motor. Then swapped all the parts I took off the new motor back to the old one so it can remain complete as possible.
      Ordered a couple of transmission gaskets that will get here Wednesday. Also need to swap over all the pulleys and tensioners because they were recently replaced on the original motor. Rear main seal to do still.
        Swapped all the idler pulleys and the Rouge Engineering under drive pulleys to the new motor.
        Getting there!
        Happy new year!
          Slowly chipping away on getting the M3 motor back in. Rear main, gear selector, and transmission input shaft seals all done.
          We all know the drill.  Pop a hole.
          Screw it in.
          Needed a bigger screw.  And slide hammer it out.
          Rear main and pilot bearing all snugged up.
          Old shift selector seal.
          New one installed.
          Transmission input seal.
          Next to do is the throw out bearing and clutch fork pivot plastic thing.  Pop on the flywheel/clutch/pressure plate.  Then mate up the motor and trans.  After that it's SMG time!!
            How much of a bear is it to pull the selector shaft seal out without scratching the bore? SOP with e30 guys is usually to embed the old seal further into the trans by hammering it in with a 12mm-ish socket and then put the new one in without the risk of gouging the seal bore.
            Boom, double seal
              Boom, double seal
              It wasn't too hard. Just took my time and didn't apply too much pressure.
                Not too m3 related but got a winter wheel setup. The m3 is displayed in its current status.
                  Picked those up from Kerry?
                    I did!  I'm really digging them on the 325xi
                      Flywheel time!
                      Took a scotch bright pad and lightly went over the surface.
                      Torqued down the new bolts to 105NM.
                      One car garage problems...
                      Picking up new exhaust manifold gaskets and nuts from BMW today.  Not too much to do after I swap over the headers.
                      Install to-do:
                      - Headers
                      - O2 Sensors
                      - Swap passenger side motor mount arm
                      - Loosely bolt up motor mounts
                      - Pressure plate
                      - Clutch fork, pivot pin, throw-out bearing
                      - Bolt on Trans to torque spec
                      - Bolt on SMG system
                      Bundle up and install motor.  Outside.  In a Wisconsin winter.
                        Header time!
                        Took off the headers and labeled both sides of the O2 sensors on both motors with different color zipties.
                        The old one is on the stand.  New one on the ground.
                        What I'm dealing with for a work space.
                          Doorman
                          I need some funky colored zip ties!!  Not sure for what but I'll think of something.
                          Last pic made me chuckle.......you really got stuff jammed in the garage!
                            Judging by that dent, you had some header clearance issues, huh?
                              You'll be happy to know that denting headers has little to no affect on losing power=)
                                Someone watches engine masters ;)
                                  That dent is scientifically designed via heat and a BFH to clear the control arm lollipop.
                                  The dent and the grinded down motor mount are due to Kummrow over tightening the motor mount arm (when they reinstalled my headers they took off the motor mount while scratching off a lot of the ceramic coating from trying to jam them in there. Their fix for the ceramic coating was black spray paint.) to block bolts, having them loosen up leading to the breaking of the aluminum motor mount arm and the motor sitting on the steering rack. I couldn't tell it was broken while in the car so I grinded down the arm to make it fit unknowingly doing unnecessary work. Ugh.
                                    Is this true??
                                      Is this true??
                                      Watch the show engine masters on YouTube
                                      They did it on a Chevy big block v8
                                        Is this true?? Sent from my SM-G900V using Tapatalk
                                        Watched it! Now I won't loose anymore sleep at night.
                                          That is a series I will definitely be following=) Get this together to bring to the ice meet if we ever have one!
