  4. The E46 M3 Journal
The E46 M3 Journal
536 Posts 34 Posters 0 Views 1 Watching
    Header time!
    Took off the headers and labeled both sides of the O2 sensors on both motors with different color zipties.
    The old one is on the stand.  New one on the ground.
    What I'm dealing with for a work space.
      Doorman
      I need some funky colored zip ties!!  Not sure for what but I'll think of something.
      Last pic made me chuckle.......you really got stuff jammed in the garage!
        Judging by that dent, you had some header clearance issues, huh?
          You'll be happy to know that denting headers has little to no affect on losing power=)
            Someone watches engine masters ;)
              That dent is scientifically designed via heat and a BFH to clear the control arm lollipop.
              The dent and the grinded down motor mount are due to Kummrow over tightening the motor mount arm (when they reinstalled my headers they took off the motor mount while scratching off a lot of the ceramic coating from trying to jam them in there. Their fix for the ceramic coating was black spray paint.) to block bolts, having them loosen up leading to the breaking of the aluminum motor mount arm and the motor sitting on the steering rack. I couldn't tell it was broken while in the car so I grinded down the arm to make it fit unknowingly doing unnecessary work. Ugh.
                Is this true??
                  Is this true??
                  Watch the show engine masters on YouTube
                  They did it on a Chevy big block v8
                    Is this true?? Sent from my SM-G900V using Tapatalk
                    Watched it! Now I won't loose anymore sleep at night.
                      That is a series I will definitely be following=) Get this together to bring to the ice meet if we ever have one!
                        Torque spec link
                        http://www.m3forum.net/m3forum/showthread.php?t=425992
                          Got the transmission all ready to go.
                          Did some maintenance while it was out.  Springs and things were replaced as well as a new clutch fork plastic pivot and throw out bearing.
                          Pics:
                          All new everything:
                          Next spring to be replaced:
                          A little sealant
                          Installed and on to the next one.  I got a new aluminum plug.
                          All done with springs and things
                          Clutch fork all set.
                          The other parts next to be installed.  Trans mounts, header gaskets and nuts.
                            What spline grease are you using/where did you acquire it?
                            I thought this car was SMG
                              The SMG and manual are the same trans I believe just a different case on the SMG for the attachments.
                                Just some Mobil 1 synthetic grease.
                                  That is correct. I'll have more detailed pics once the engine and trans get married.
                                    The life blood has arrived!
                                    Also got a DVD of BMWs moving under their own power as I forgot what that looks like and needed a refresher.
                                      A DVD of bmws moving under their own power.
                                      [emoji16] friggin hilarious
                                        Doorman
                                        emoji16.png friggin hilarious
                                        If that DVD seems like it's TOO overwhelming/too much too soon for you......we could all make clips of us pushing our cars and make a DVD......baby steps brother!
                                          That would probably sell!!
