Replacing seals in my M20
Got the head out yesterday and off to the shop for surfacing. Now comes the cleaning and painting. Won't get to the reassembly until next week as several parts aren't scheduled to arrive until MON/TUE. Have plenty of cleaning to keep me busy though.
Everything came apart astoundingly easily, even the exhaust mani nuts. Did have cause for a near heart attack yesterday though. I was having a problem getting the torx screw that holds the crank position sensor out of the holder and so decided to tap it with a hammer. Two taps and the whole thing broke off! For about five seconds I had thought that the head was shot, thinking that the mount was cast into the head, until I realized that the holder was bolted on. Called BMW and they actually had one they could get for about $7.
Where did you take the head to be machined?
If it is Automotive Supply I would call them up and tell them not to touch it.
They have done nothing but ruin parts that I or others have brought there. -
Dropped it off with my Indy down the street. They sent it out to a shop they trust. Don't know the name. I'm sure it wasn't Automotive Supply, though.
Found out the shop is Kramer & Ridge. They have found that the head is damaged to the point that it would probably have to be machined quite a bit. They are suggesting replacing it. Anyone have a decent 325 head that would work well on an "I" engine, or recommendations on which one to look for?
Well, at sort of a stand-still for now on the project. Need to find a new head optimally as I don't have faith that the current one can be repaired and surfaced well enough to make it work. That said, there don't seem to be many heads out there for much under $450. Gonna have to wait a few weeks until my wife gets home from her trip to Switzerland that she and her family have been planning for months, and maybe then I can get Humpty Dumpty back together again.
My fallback options are to either sell the car as-is and hope to get something decent for it considering its overall condition, or else part it out.
Eric
What is said damage to the head?
Most certainly not grounds for a part out. -
just go for it! tearing down an m20 to the head is simple enough to do again in the future if it doesnt work out. seems like a win over selling the car!!
Selling and parting aren't my first choices. The problem is that this is my DD and if I can't get it on the road by the time the snow flies, I need a car. I'm not driving my 66 Charger in WI winters, and I don't have the money or space for another car to DD while the E30 sits.
I'm sure I'll find something, it's just a matter of what and when.
Said head damage is that it has a small nick on the undersurface that has to be welded, but it's also warped. The shop felt that in order to surface it enough to use it would require a hugely thick head gasket. Not sure I want to have to rely on a gasket to obtain proper clearance for the pistons and valves.
Well, decided to pop for the 855 casting head that was up for sale on Ebay. Not the place I would have preferred to buy, but since everything else I found anywhere was going for around $500 or more, $299 seemed pretty reasonable assuming that the thing isn't junk. I guess I'll find out for sure when I received it and take it in to get it surfaced.
Car-part.com would have all those listings.
Should have the new head sometime this week. May have to wait another week to get it surfaced as it will have to be disassembled in order to do so. Not sure if I have the tools or knowledge to take out and re-install valves myself.
My Ebay head arrived on Friday. Off to the machine shop on Tuesday and hopefully begin the process of re-assembly later this week!
Well, hope to get started on re-assembly this weekend and maybe on the road by Monday. Any suggestions for a newbie to head gasket replacement regarding setting the gasket and timing?
Got new head bolts, took a tap to each of the bolt holes to clean them up. All holes are dry and I took my parts retriever magnet to each of the holes to fish out any metal shavings from the tap. Took a razor blade to the top of the block and cleaned all the remnants of the old gasket, and cleaned the front of the block to set myself up for success on the water pump.
Weekend wasn't engine re-assembly friendly. I did, however, manage to get the head situated on the block last night with bypass hose reconnected and head bolts turned in just enough to have the caps flush with the metal. Today comes head bolt torqueing, valve adjustment, exhaust manifold attachment and hopefully thermostat housing and hose attachment.
OK. Have the head bolts torqued to 22 ft-lb, and then torqued 90 degrees twice. I just got my days muscle resistance and cardio workout in (at least resistance exercise for my right arm anyway). Remaining goals for today are exhaust manifold re-attach, thermostat housing re-attach and hoses.
