  4. Replacing seals in my M20
56 Posts 9 Posters 1.0k Views 1 Watching
  • 6670charger6
    6670charger6
    6670charger
    Well, at sort of a stand-still for now on the project. Need to find a new head optimally as I don't have faith that the current one can be repaired and surfaced well enough to make it work. That said, there don't seem to be many heads out there for much under $450. Gonna have to wait a few weeks until my wife gets home from her trip to Switzerland that she and her family have been planning for months, and maybe then I can get Humpty Dumpty back together again.
    My fallback options are to either sell the car as-is and hope to get something decent for it considering its overall condition, or else part it out.
    Eric
    Appleton, WI
      Definitely not grounds to part out the car lol.
        What is said damage to the head?
        Most certainly not grounds for a part out.
          just go for it! tearing down an m20 to the head is simple enough to do again in the future if it doesnt work out. seems like a win over selling the car!!
          • 6670charger6
            6670charger6
            6670charger
            Selling and parting aren't my first choices. The problem is that this is my DD and if I can't get it on the road by the time the snow flies, I need a car. I'm not driving my 66 Charger in WI winters, and I don't have the money or space for another car to DD while the E30 sits.
            I'm sure I'll find something, it's just a matter of what and when.
            Appleton, WI
            • 6670charger6
              6670charger6
              6670charger
              Said head damage is that it has a small nick on the undersurface that has to be welded, but it's also warped. The shop felt that in order to surface it enough to use it would require a hugely thick head gasket. Not sure I want to have to rely on a gasket to obtain proper clearance for the pistons and valves.
              Appleton, WI
              • 6670charger6
                6670charger6
                6670charger
                Well, decided to pop for the 855 casting head that was up for sale on Ebay. Not the place I would have preferred to buy, but since everything else I found anywhere was going for around $500 or more, $299 seemed pretty reasonable assuming that the thing isn't junk. I guess I'll find out for sure when I received it and take it in to get it surfaced.
                Appleton, WI
                  Did you call any of the larger parts recyclers in Wisconsin? One of them would be bound to have one
                    Car-part.com would have all those listings.
                    • 6670charger6
                      6670charger6
                      6670charger
                      Should have the new head sometime this week. May have to wait another week to get it surfaced as it will have to be disassembled in order to do so. Not sure if I have the tools or knowledge to take out and re-install valves myself.
                      Appleton, WI
                      • 6670charger6
                        6670charger6
                        6670charger
                        My Ebay head arrived on Friday. Off to the machine shop on Tuesday and hopefully begin the process of re-assembly later this week!
                        Appleton, WI
                        • 6670charger6
                          6670charger6
                          6670charger
                          Well, hope to get started on re-assembly this weekend and maybe on the road by Monday. Any suggestions for a newbie to head gasket replacement regarding setting the gasket and timing?
                          Got new head bolts, took a tap to each of the bolt holes to clean them up. All holes are dry and I took my parts retriever magnet to each of the holes to fish out any metal shavings from the tap. Took a razor blade to the top of the block and cleaned all the remnants of the old gasket, and cleaned the front of the block to set myself up for success on the water pump.
                          Appleton, WI
                          • 6670charger6
                            6670charger6
                            6670charger
                            Weekend wasn't engine re-assembly friendly. I did, however, manage to get the head situated on the block last night with bypass hose reconnected and head bolts turned in just enough to have the caps flush with the metal. Today comes head bolt torqueing, valve adjustment, exhaust manifold attachment and hopefully thermostat housing and hose attachment.
                            post-2609-0-06584000-1442418477thumb.jp
                            post-2609-0-25711400-1442418486thumb.jp
                            post-2609-0-55166600-1442418500thumb.jp
                            Appleton, WI
                            • 6670charger6
                              6670charger6
                              6670charger
                              OK. Have the head bolts torqued to 22 ft-lb, and then torqued 90 degrees twice. I just got my days muscle resistance and cardio workout in (at least resistance exercise for my right arm anyway). Remaining goals for today are exhaust manifold re-attach, thermostat housing re-attach and hoses.
                              Appleton, WI
                                It is quite a workout installing a head. Looking good!
                                • 6670charger6
                                  6670charger6
                                  6670charger
                                  A few more pics from yesterday. Got the intake and valve body on, as well as the exhaust manifolds connected. Today, got the valve body torqued in, the throttle cables attached, the thermostat housing attached, and the hoses for it that were in the car re-attached to it. Plugged in the fuel injectors, fuel lines and thermostat cables, and pretty much got the left side of the engine done save for the bellows, MAF and air box. Also got the new water pump and gasket attached finger tight. Hope to torque the water pump bolts and get most if not all of the timing belt in tomorrow. Might even get him on the road!!
                                  post-2609-0-07601800-1442525613thumb.jp
                                  post-2609-0-33609600-1442525622thumb.jp
                                  post-2609-0-76243400-1442525630thumb.jp
                                  post-2609-0-72588400-1442525639thumb.jp
                                  Appleton, WI
                                  • 6670charger6
                                    6670charger6
                                    6670charger
                                    Made really good progress on Friday. Got the timing belt on and nearly complete. Only thing left is to put the fan on and put the coolant in, then hope that it starts and runs right.
                                    I assume that putting the antifreeze in goes like usual; pour in through overflow tank with engine running, heater defroster on and bleed screw cracked? Haven't refilled a coolant-less engine in quite a while.
                                    Appleton, WI
                                    • 6670charger6
                                      6670charger6
                                      6670charger
                                      post-2609-0-65026900-1442714173thumb.jp
                                      post-2609-0-96273000-1442714220thumb.jp
                                      post-2609-0-77978200-1442714267thumb.jp
                                      post-2609-0-69169600-1442714302thumb.jp
                                      Appleton, WI
                                        Nice work!
                                        I have always had great results filling the engine with coolant through the top radiator hose, first into the block, then into the radiator, then fill the reservoir. You are correct that the heater blend valve should be set to full hol
                                        • 6670charger6
                                          6670charger6
                                          6670charger
                                          Thanks!! Never thought of that. The thoughts of starting the engine on basically no coolant and running it that way for several minutes while it slowly sucked antifreeze through a straw really had me worried it wouldn't fill fast enough.
                                          Appleton, WI
