pistonse30
    Going to spray the back portion of the gauge black to make it more incognito? Looks like you did a very tidy job cutting=)
      ^exact thoughts.
        Yes, I will. I have to figure out how to secure it in there. The spindle that came with it is too big. a bunch of electrical tape?
          Dab of silicone on the top and bottom where it touches the vent?
            Or just hot glue, firm but easy to get off if needed.
            • TCDT
              TCDT
              TCD
              Hot glue, silicone, electrical tape?  haha You guys are :D
                Enlighten us! Haha
                If you say Velcro... #overthehill
                • CMartC
                  CMartC
                  CMart
                  I can't 100% tell how it is sitting, but if you are looking to secure it from the back maybe a black hose clamp?
                  Excursion 7.3
                  E30 LS1
                    I would even think a piece of hose (or PVC pipe maybe) that has the same ID as the OD of the gauge. Slip it over the gauge up to the front. It could pinch the vent ribs between the gauge lip and the hose, applying even pressure hold around the entire gauge. Just a thought.
                      It is pretty tight in there after sanding the upper and lower to make the gauge fit. I might use some of that interior tar that I used to hold on the inner door plastic. Simple, black and I can remove it if I need to with ease.
                      Unless TCD aka "Captain Velcro" wants to share the knowledge. ;)
                      - Ordered this guy. http://jbperf.com/dual_VR/v2_1.html
                      ^Traction control!!!!
                      - Received my VAC 12 to 14mm vanos bolt.
                      - Got the tiling done in the bathroom surround. Need to tile the floor, drop off the wet table saw and pick up my air compressor so I can blow out the head bolt threads in the block.
                      - Ready to finish my Megasquirt wiring. Need to figure out how to wire up the traction control still.
                        Got the air compressor...that's about it. Work has been busy with positive things!
                          Popped on the S54 oil filter housing and the power steering. Torqued everything down with loc-tite. 9df5eda5e72c541f2eafcf5f4a92f732.jpg I cleaned out the threads in the block for the head bolts then I starting reading that people prep their block with a honing stone before they install the CES cut-ring head gasket. Should I do this? Thoughts? Sent from my SM-G900V using Tapatalk
                            I didn't know ECS made a gasket as well.
                            I am running a similar setup, and from what I was seeing most people that surface the block with a stone haven't had the block decked before. Like myself!
                              Edit:  CES cut-ring HG.
                              Did you prep the block yourself?
                                I bought the same gasket, and also bought a copper spacer for my setup.
                                I did do the stone/sandpaper because mine had never been done. It actually worked pretty well.
                                In your case I would grab a straight bar and some feeler gauges and find out if anything is not straight.
                                • T
                                  T
                                  tsweers89
                                  Grab a straight edge and check. Also post up on bimmerforums FI section asking for help prepping the block. Many different methods. May be a better method for the cut ring.
                                  • T
                                    T
                                    tsweers89
                                    Even CES says to prep the block with stoned http://www.bimmerforums.com/forum/showthread.php?1838028-CES-Motorsport-Cut-Ring-Head-Gasket-Copper-spacer-combo-install-guide&highlight=Ces+cutring
                                      Sorting out a couple more ground wires then I should be all done with the dme side of the wiring harness.
                                      Still need to wire up the new gauges and the GM IAT sensor.
                                      Heat Sink'd the coil drivers.
                                      Where I left it.
                                        Doorman
                                        DrLeadFoot said:
                                        Sorting out a couple more ground wires then I should be all done with the dme side of the wiring harness. Still need to wire up the new gauges and the GM IAT sensor.Heat Sink'd the coil drivers.298e32be921f57e58b1497895ba1e055.jpgWhere I left it. cbef45c8c3344448d548da66d5863f7a.jpgSent from my SM-G900V using Tapatalk
                                        Are those puzzle pieces on your socks!?!?!
                                        Hipsters.......sigh.....
                                          Doorman said:
                                          Sorting out a couple more ground wires then I should be all done with the dme side of the wiring harness. Still need to wire up the new gauges and the GM IAT sensor.Heat Sink'd the coil drivers.Where I left it. Sent from my SM-G900V using Tapatalk
                                          That's my signature Realtor "look". You wanna buy a house??!
