    It was really awkward trying to explain to my woman why I was laughing so hard at my phone... You guys are fantastic hahaha
      ALPINA wheels
      Andy
      Loves
      Penis
      In
      North
      Appleton
        HAHA
        Back on topic...for now.
        Out with the old, in with the new!!
        Brand new S54 oil housing on the left, S52 on the right.
        Just ordered the 14mm to 12mm Vanos banjo bolt from VAC Motorsports.
        That housing takes up so much room!
          any reason you didn't use something like the champion oil filter relocation with a thermostat? Not real sure about the benefits of s54 housing, though. I just love the look of a hidden oil filter haha.
            Less work, oem reliability and avoiding a lot of a/n fittings.
            I definitely thought about getting the vac or Achilles units but $$$..
              Vent oil temp gauge install:
              Mark your spots to cut
              Cut
              Small cuts and some sanding of the upper and lower edges and she fits!
              Now on to the fun part.
              That's all for now, folks!
                Going to spray the back portion of the gauge black to make it more incognito? Looks like you did a very tidy job cutting=)
                  ^exact thoughts.
                    Yes, I will. I have to figure out how to secure it in there. The spindle that came with it is too big. a bunch of electrical tape?
                      Dab of silicone on the top and bottom where it touches the vent?
                        Or just hot glue, firm but easy to get off if needed.
                        • TCDT
                          TCDT
                          TCD
                          Hot glue, silicone, electrical tape?  haha You guys are :D
                            Enlighten us! Haha
                            If you say Velcro... #overthehill
                            • CMartC
                              CMartC
                              CMart
                              I can't 100% tell how it is sitting, but if you are looking to secure it from the back maybe a black hose clamp?
                              Excursion 7.3
                              E30 LS1
                                I would even think a piece of hose (or PVC pipe maybe) that has the same ID as the OD of the gauge. Slip it over the gauge up to the front. It could pinch the vent ribs between the gauge lip and the hose, applying even pressure hold around the entire gauge. Just a thought.
                                  It is pretty tight in there after sanding the upper and lower to make the gauge fit. I might use some of that interior tar that I used to hold on the inner door plastic. Simple, black and I can remove it if I need to with ease.
                                  Unless TCD aka "Captain Velcro" wants to share the knowledge. ;)
                                  - Ordered this guy. http://jbperf.com/dual_VR/v2_1.html
                                  ^Traction control!!!!
                                  - Received my VAC 12 to 14mm vanos bolt.
                                  - Got the tiling done in the bathroom surround. Need to tile the floor, drop off the wet table saw and pick up my air compressor so I can blow out the head bolt threads in the block.
                                  - Ready to finish my Megasquirt wiring. Need to figure out how to wire up the traction control still.
                                    Got the air compressor...that's about it. Work has been busy with positive things!
                                      Popped on the S54 oil filter housing and the power steering. Torqued everything down with loc-tite. 9df5eda5e72c541f2eafcf5f4a92f732.jpg I cleaned out the threads in the block for the head bolts then I starting reading that people prep their block with a honing stone before they install the CES cut-ring head gasket. Should I do this? Thoughts? Sent from my SM-G900V using Tapatalk
                                        I didn't know ECS made a gasket as well.
                                        I am running a similar setup, and from what I was seeing most people that surface the block with a stone haven't had the block decked before. Like myself!
                                          Edit:  CES cut-ring HG.
                                          Did you prep the block yourself?
