pistonse30
    Even though they are common grounds, I would run all separates wires to a common point on the engine block for best results. Don't connect multiple grounds before the engine block.
      And great job!! This is exciting stuff.
        Shouldn't I use the grounding point that the ECU uses?
          Some wedding shots of the E30
          http://jbephotography.zenfolio.com/p927518357/h49c3463b#h49c35677
          http://jbephotography.zenfolio.com/p927518357/h49C35677#h49c3559d
            That's awesome!
              24d16e580f66996845abf8a56f869244.jpg8d1b0775376a1a4dc0d1bbc1a9f7773f.jpg7332f6ee05dc607b7eb4ed0eb14b335d.jpg
                Haha. Que the music!
                      Maybe next paycheck....
                        Coils are all wired up.  I need to see if I need to run them to grounds coming from the harness or if I can just run them directly to the chassis ground.  I'm leaning towards running the grounds to the harness.
                        I disconnected the grounds from the MS3 and Expansion board from the pins.  I'll run these to the chassis ground for sure.  I don't want to overload those pins.
                        I still feel like I'm winging it so please help with any input.
                        A wired up coil.
                        From DBurt86's build thread:
                        http://s314.photobucket.com/user/dburt86/media/coil%20driver_zpssqcdevwu.png.html
                        All sealed up.
                          This is what they are resting on when in the stock 413 red label ECU. I could use this as the heat sink and bolt it to the cover to dissipate the heat. What do you think?
                          19472362392402dd33fd1b.jpg __________________
                            Doorman
                            This is some mad scientist stuff bro!!!
                              It's unloading in third
                                http://www.dailymotion.com/video/x11lvw_thomas-dolby-she-blinded-me-with-sc_music
                                  Snap is working his magic!!! #ceramiccoating #insideandout
                                  • dastuzD
                                    dastuzD
                                    dastuz
                                    Those look pretty!
                                      Form follows function. Increasing thermal efficiency in the name of broken axles is the name of the game
                                        But...... #wheresthegold
                                          Do I seriously need to remove and sandblast my exhaust manifold for a third time....
