pistonse30
    Lmfao
      And they're off!
      First one done!  I think this fuel relay one was supposed to be on a relay.  I'll figure it out soon enough.
      Got a good chunk started.  Also have a lot of questions.
      Wire 27x on the expansion board harness goes to pin #7 on the monotronic side for the VVT.  Still going through the question marks one by one.
        So happy I bought a full plug-and-play MS2 setup after seeing this.... Yikes.
          Nah, just a lot of information checking. He will get it just fine
            Turned my attention to the grounds.  I might take a different approach by making a separate grounding block that connects at the common chassis ground.  I'm fearful that I might be overloading some pins by attaching more than one ground wire.  Thoughts?
            I still need to wire the coil drivers so there are 6 more grounds there.
            On to the crank signal wires with the shielding.  I cut an old cable wire from the ceiling of my basement and cut/pealed the shielding to re-wrap the signal wires after I soldered them.
            Not too pretty but I'll wrap it in electrical tape to clean it up and secure it.
            I need to get some 18 & 20 gauge wire and solder in my coils.  Any input on how to ground all these wires would be great.  Thanks for looking!
              I feel very overwhelmed at the moment but Snap and Derek (bimmerforums.com member) have been huge helps.  It is the unknowns that I have with how the software works that concern me.  I also feel like I need to put some resistors somewhere but I haven't looked into that yet.
              Your wife has to think you're having an affair with how many times I text you at all hours of the day/night.  #jakefromstatefarm
                Uhhhhh khakis
                  Home depot sells shielded wire too.
                  Grounding everything to the same chassis ground is definitely a great idea. I would be less worried about overloading grounds and only slightly more concerned with any noise in the signals due to shared grounds. A handful of the ground pins are the same on the harness (multiple pins with continuity to eachother) so that even isnt much of a concern depending on which components are grounded together.
                  Any excessive electrical noise for a component will how up in a log file . Youre going to love the diagnostic capability of being able to see what all your sensors are doing
                    Even though they are common grounds, I would run all separates wires to a common point on the engine block for best results. Don't connect multiple grounds before the engine block.
                      And great job!! This is exciting stuff.
                        Shouldn't I use the grounding point that the ECU uses?
                          Some wedding shots of the E30
                          http://jbephotography.zenfolio.com/p927518357/h49c3463b#h49c35677
                          http://jbephotography.zenfolio.com/p927518357/h49C35677#h49c3559d
                            That's awesome!
                              24d16e580f66996845abf8a56f869244.jpg8d1b0775376a1a4dc0d1bbc1a9f7773f.jpg7332f6ee05dc607b7eb4ed0eb14b335d.jpg
                                Haha. Que the music!
                                      Maybe next paycheck....
                                        Coils are all wired up.  I need to see if I need to run them to grounds coming from the harness or if I can just run them directly to the chassis ground.  I'm leaning towards running the grounds to the harness.
                                        I disconnected the grounds from the MS3 and Expansion board from the pins.  I'll run these to the chassis ground for sure.  I don't want to overload those pins.
                                        I still feel like I'm winging it so please help with any input.
                                        A wired up coil.
                                        From DBurt86's build thread:
                                        http://s314.photobucket.com/user/dburt86/media/coil%20driver_zpssqcdevwu.png.html
                                        All sealed up.
                                          This is what they are resting on when in the stock 413 red label ECU. I could use this as the heat sink and bolt it to the cover to dissipate the heat. What do you think?
                                          19472362392402dd33fd1b.jpg __________________
