pistonse30
    Uhhhhh khakis
      Home depot sells shielded wire too.
      Grounding everything to the same chassis ground is definitely a great idea. I would be less worried about overloading grounds and only slightly more concerned with any noise in the signals due to shared grounds. A handful of the ground pins are the same on the harness (multiple pins with continuity to eachother) so that even isnt much of a concern depending on which components are grounded together.
      Any excessive electrical noise for a component will how up in a log file . Youre going to love the diagnostic capability of being able to see what all your sensors are doing
        Even though they are common grounds, I would run all separates wires to a common point on the engine block for best results. Don't connect multiple grounds before the engine block.
          And great job!! This is exciting stuff.
            Shouldn't I use the grounding point that the ECU uses?
              Some wedding shots of the E30
              http://jbephotography.zenfolio.com/p927518357/h49c3463b#h49c35677
              http://jbephotography.zenfolio.com/p927518357/h49C35677#h49c3559d
                That's awesome!
                  24d16e580f66996845abf8a56f869244.jpg8d1b0775376a1a4dc0d1bbc1a9f7773f.jpg7332f6ee05dc607b7eb4ed0eb14b335d.jpg
                    Haha. Que the music!
                          Maybe next paycheck....
                            Coils are all wired up.  I need to see if I need to run them to grounds coming from the harness or if I can just run them directly to the chassis ground.  I'm leaning towards running the grounds to the harness.
                            I disconnected the grounds from the MS3 and Expansion board from the pins.  I'll run these to the chassis ground for sure.  I don't want to overload those pins.
                            I still feel like I'm winging it so please help with any input.
                            A wired up coil.
                            From DBurt86's build thread:
                            http://s314.photobucket.com/user/dburt86/media/coil%20driver_zpssqcdevwu.png.html
                            All sealed up.
                              This is what they are resting on when in the stock 413 red label ECU. I could use this as the heat sink and bolt it to the cover to dissipate the heat. What do you think?
                              19472362392402dd33fd1b.jpg __________________
                                Doorman
                                This is some mad scientist stuff bro!!!
                                  It's unloading in third
                                    http://www.dailymotion.com/video/x11lvw_thomas-dolby-she-blinded-me-with-sc_music
                                      Snap is working his magic!!! #ceramiccoating #insideandout
                                      • dastuzD
                                        dastuzD
                                        dastuz
                                        Those look pretty!
                                          Form follows function. Increasing thermal efficiency in the name of broken axles is the name of the game
