pistonse30
    He got it as good as he could. I guess the belt sander over heated 2 times
      Before
      After
      Now you're beautiful!
      Its ready for pickup whenever
        Quality is the name of the game
          Ummmmmmm
            Lol
              Lmfao
                And they're off!
                First one done!  I think this fuel relay one was supposed to be on a relay.  I'll figure it out soon enough.
                Got a good chunk started.  Also have a lot of questions.
                Wire 27x on the expansion board harness goes to pin #7 on the monotronic side for the VVT.  Still going through the question marks one by one.
                  So happy I bought a full plug-and-play MS2 setup after seeing this.... Yikes.
                    Nah, just a lot of information checking. He will get it just fine
                      Turned my attention to the grounds.  I might take a different approach by making a separate grounding block that connects at the common chassis ground.  I'm fearful that I might be overloading some pins by attaching more than one ground wire.  Thoughts?
                      I still need to wire the coil drivers so there are 6 more grounds there.
                      On to the crank signal wires with the shielding.  I cut an old cable wire from the ceiling of my basement and cut/pealed the shielding to re-wrap the signal wires after I soldered them.
                      Not too pretty but I'll wrap it in electrical tape to clean it up and secure it.
                      I need to get some 18 & 20 gauge wire and solder in my coils.  Any input on how to ground all these wires would be great.  Thanks for looking!
                        I feel very overwhelmed at the moment but Snap and Derek (bimmerforums.com member) have been huge helps.  It is the unknowns that I have with how the software works that concern me.  I also feel like I need to put some resistors somewhere but I haven't looked into that yet.
                        Your wife has to think you're having an affair with how many times I text you at all hours of the day/night.  #jakefromstatefarm
                          Uhhhhh khakis
                            Home depot sells shielded wire too.
                            Grounding everything to the same chassis ground is definitely a great idea. I would be less worried about overloading grounds and only slightly more concerned with any noise in the signals due to shared grounds. A handful of the ground pins are the same on the harness (multiple pins with continuity to eachother) so that even isnt much of a concern depending on which components are grounded together.
                            Any excessive electrical noise for a component will how up in a log file . Youre going to love the diagnostic capability of being able to see what all your sensors are doing
                              Even though they are common grounds, I would run all separates wires to a common point on the engine block for best results. Don't connect multiple grounds before the engine block.
                                And great job!! This is exciting stuff.
                                  Shouldn't I use the grounding point that the ECU uses?
                                    Some wedding shots of the E30
                                    http://jbephotography.zenfolio.com/p927518357/h49c3463b#h49c35677
                                    http://jbephotography.zenfolio.com/p927518357/h49C35677#h49c3559d
                                      That's awesome!
                                        24d16e580f66996845abf8a56f869244.jpg8d1b0775376a1a4dc0d1bbc1a9f7773f.jpg7332f6ee05dc607b7eb4ed0eb14b335d.jpg
                                          Haha. Que the music!
