  4. '88 E30
'88 E30
    Harness is now (kind of) on the s50
    That's about it
      Looking good
        Is it done yet?
          CYoung said:
          Is it done yet?
          I'm at that point where all the parts I've ordered are currently installed. But now I have to make another order for more crap
            Left to order:
            Clutch/PP/FW
            Slave cylinder
            driveshaft
            Giubo
            O2 sensor
            Random barbed connectors to bypass coolant lines to TB & to route the PCV line to the bimmerworld intake elbow
            Vac line from fpr to intake manifold (may be able to reuse mine, unsure if long enough)
            Figure out what to do with purge valve
            I can either vent to atmosphere with that line from the tank, cap off the nipple on the TB and just keep the sensor connected to the purge valve (?? Will it throw a CEL) or just run the hose from the tank inline with the purge valve and plug it into the TB (essentially just bypass the charcoal canister thing) and keep harness plugged into purge valve.
            If I do the second option I'm not sure if the purge valve still even works so it may just be better to vent to atmosphere.
            No clue yet
              Order the febi slave and guibo. What clutch did you decide on?
                Haven't really decided
                  Just ordered:
                  Core support
                  Mishimoto radiator
                  Bimmerworld radiator hoses
                  Clutch/pp/fw (comes with release bearing, pilot bearing, hardware)
                  Slave cylinder
                  BMW coolant
                  Still to order:
                  98 m3 Driveshaft
                  E30 csb
                  Flex disc
                  O2 sensor
                  Trans fluid
                  Diff fluid
                  Shifter rebuild kit
                  Shit adds up quick
                    Christmas in July
                      what clutch did you decide on?
                      and hey I gotta ask how much did you get your s50 for? I see s52's on car part for 1500$ and it makes it very tempting. an extra 1000$ nets me a good chunk of NA hp but I'm not sure if buying a very used s52 is a good idea ha.
                        I went with the gripforce stage 2 clutch. Read some good reviews on bimmerforums of guys being skeptical, but they had good things to say. After I put it in and beat on it for a while I'll post my review as well. It's a cheap alternative at this point. If I have to tear it out in a year, lesson learned I spose.
                        I picked up the s50 with great compression, full harness, zf trans and DME (literally everything to swap) for $1450. Some stuff I won't be using cause I was already 24v. But now I have spares which is nice
                          Coolant, febi clutch slave, core support and radiator have showed up
                            removable core support using stock core support?
                              Yes sir
                                The CSB is mounted on the e36 DS on the opposite shaft than the e30 DS.  Just make sure the offset side is mounted the same as the e30 DS was.  This sounds confusing but when you see it in front of you and side-by-side it makes perfect sense.
                                  Thanks for the heads up. Still on the fence about where to order from. Wholesale something or other is where I'll most likely go.
                                  As far as shift stuff goes
                                  I was thinking to just order the condor kit with the short knob (?) the uuc evo3 with dssr is like $460. I've been told it's worth it, but idk. Rebuilt stock stuff with Delrin would still be better than nothing I suppose
                                    I'm not sure what you are running for engine and trans mounts, but I built this floor mount shifter like the AKG one and MAN it's amazing. It's not finished in this picture, but I have a solid brass handle on it now and it's killer.
                                    This is in my daily beater.
                                      I forgot about the best part. You get to delete the bitch clip!!! Super easy install.
                                        Everything's out of the car right now, so the bitch clip won't be that big of a bitch haha
                                          But it won't stay that way forever right?
