  4. '88 E30
'88 E30
savebigmoney
    I went with the gripforce stage 2 clutch. Read some good reviews on bimmerforums of guys being skeptical, but they had good things to say. After I put it in and beat on it for a while I'll post my review as well. It's a cheap alternative at this point. If I have to tear it out in a year, lesson learned I spose.
    I picked up the s50 with great compression, full harness, zf trans and DME (literally everything to swap) for $1450. Some stuff I won't be using cause I was already 24v. But now I have spares which is nice
      Coolant, febi clutch slave, core support and radiator have showed up
        removable core support using stock core support?
          Yes sir
            The CSB is mounted on the e36 DS on the opposite shaft than the e30 DS.  Just make sure the offset side is mounted the same as the e30 DS was.  This sounds confusing but when you see it in front of you and side-by-side it makes perfect sense.
              Thanks for the heads up. Still on the fence about where to order from. Wholesale something or other is where I'll most likely go.
              As far as shift stuff goes
              I was thinking to just order the condor kit with the short knob (?) the uuc evo3 with dssr is like $460. I've been told it's worth it, but idk. Rebuilt stock stuff with Delrin would still be better than nothing I suppose
                I'm not sure what you are running for engine and trans mounts, but I built this floor mount shifter like the AKG one and MAN it's amazing. It's not finished in this picture, but I have a solid brass handle on it now and it's killer.
                This is in my daily beater.
                  I forgot about the best part. You get to delete the bitch clip!!! Super easy install.
                    Everything's out of the car right now, so the bitch clip won't be that big of a bitch haha
                      But it won't stay that way forever right?
                        The engine and trans will come out before the shifter ever gets loose again
                          Okay, anyways. I'm just saying it's an epic setup and I'm never gonna miss a gear again. Amazing to drive with.
                            I believe it! I just want a decent shifter feel. The car has other areas that need attention first lol. Like putting it back together
                              I have the uuc w/dssr. The dssr is awesome but I would rather have a floor mount shifter. Don't get me wrong, its a nice product but I don't really care for a shorter throw.
                              Sent from my potato phone
                                I like mine a lot. But I've never shifted a floor shifter.
                                  I just ended up going with the condor ssk. Gonna toss a zhp knob on it and call it fine for now. Maybe pick up the dssr for it at a later date.
                                  Or buy it the next time the engine comes out. Lol.
                                    Have you used a z3 shifter before in an e30? Or what helped you make the decision.
                                      Never used a z3 shifter. Never used a zhp knob. But I have used sloppy shifter and I know I hate them.
                                      • CMartC
                                        CMartC
                                        CMart
                                        I have a Z3 in the M62 and damn is it short. Won't know if I like it until I have some hours behind the wheel, but I have never owned a car with a throw as short as this.
                                        Excursion 7.3
                                        E30 LS1
                                          yea I'm only saying that because I tried the z3 shifter and definitely did NOT like it.
