  4. '88 E30
'88 E30
    Left to order:
    Clutch/PP/FW
    Slave cylinder
    driveshaft
    Giubo
    O2 sensor
    Random barbed connectors to bypass coolant lines to TB & to route the PCV line to the bimmerworld intake elbow
    Vac line from fpr to intake manifold (may be able to reuse mine, unsure if long enough)
    Figure out what to do with purge valve
    I can either vent to atmosphere with that line from the tank, cap off the nipple on the TB and just keep the sensor connected to the purge valve (?? Will it throw a CEL) or just run the hose from the tank inline with the purge valve and plug it into the TB (essentially just bypass the charcoal canister thing) and keep harness plugged into purge valve.
    If I do the second option I'm not sure if the purge valve still even works so it may just be better to vent to atmosphere.
    No clue yet
      Order the febi slave and guibo. What clutch did you decide on?
        Haven't really decided
          Just ordered:
          Core support
          Mishimoto radiator
          Bimmerworld radiator hoses
          Clutch/pp/fw (comes with release bearing, pilot bearing, hardware)
          Slave cylinder
          BMW coolant
          Still to order:
          98 m3 Driveshaft
          E30 csb
          Flex disc
          O2 sensor
          Trans fluid
          Diff fluid
          Shifter rebuild kit
          Shit adds up quick
            Christmas in July
              what clutch did you decide on?
              and hey I gotta ask how much did you get your s50 for? I see s52's on car part for 1500$ and it makes it very tempting. an extra 1000$ nets me a good chunk of NA hp but I'm not sure if buying a very used s52 is a good idea ha.
                I went with the gripforce stage 2 clutch. Read some good reviews on bimmerforums of guys being skeptical, but they had good things to say. After I put it in and beat on it for a while I'll post my review as well. It's a cheap alternative at this point. If I have to tear it out in a year, lesson learned I spose.
                I picked up the s50 with great compression, full harness, zf trans and DME (literally everything to swap) for $1450. Some stuff I won't be using cause I was already 24v. But now I have spares which is nice
                  Coolant, febi clutch slave, core support and radiator have showed up
                    removable core support using stock core support?
                      Yes sir
                        The CSB is mounted on the e36 DS on the opposite shaft than the e30 DS.  Just make sure the offset side is mounted the same as the e30 DS was.  This sounds confusing but when you see it in front of you and side-by-side it makes perfect sense.
                          Thanks for the heads up. Still on the fence about where to order from. Wholesale something or other is where I'll most likely go.
                          As far as shift stuff goes
                          I was thinking to just order the condor kit with the short knob (?) the uuc evo3 with dssr is like $460. I've been told it's worth it, but idk. Rebuilt stock stuff with Delrin would still be better than nothing I suppose
                            I'm not sure what you are running for engine and trans mounts, but I built this floor mount shifter like the AKG one and MAN it's amazing. It's not finished in this picture, but I have a solid brass handle on it now and it's killer.
                            This is in my daily beater.
                              I forgot about the best part. You get to delete the bitch clip!!! Super easy install.
                                Everything's out of the car right now, so the bitch clip won't be that big of a bitch haha
                                  But it won't stay that way forever right?
                                    The engine and trans will come out before the shifter ever gets loose again
                                      Okay, anyways. I'm just saying it's an epic setup and I'm never gonna miss a gear again. Amazing to drive with.
                                        I believe it! I just want a decent shifter feel. The car has other areas that need attention first lol. Like putting it back together
                                          I have the uuc w/dssr. The dssr is awesome but I would rather have a floor mount shifter. Don't get me wrong, its a nice product but I don't really care for a shorter throw.
                                          Sent from my potato phone
