pistonse30
    ARP doesn't mention anything about a retorque, its actually in their FAQ's saying that you shouldn't need to. Not that it is a horrible idea, but its a heck of a lot of work on these motors. Standard sockets don't fit between the cam trays and head, and getting the VC off is no fun ;)
    Sucks that it failed, but luckily its not a hard job!
      So not coming to Concours Saturday now?
        I'll be e46in'. Don't get sunburn from that engine light.
          I gotta wonder why you wouldn't go with a cut ring gasket or o rings? And do you have any logs? Did you ever get rid of that richness?
          I would definitely borrow a nice caliper and measure if those bad boys stretched. I'm kind of excited to see what the pistons look like.
            From what I can see there is no need to re-tighten the head bolts on the engine.  Not according to the replacement and torque procedure at least.
              There is hardly any room between the 87mm cylinders. Not sure if I can o-ring it
                I'm still running rich. It drops into the 10s at 4-6k
                  http://www.cesmotorsport.com/documents/94.html
                  They have an 87mm cut ring gasket for ya! Everyone is raving about them on BF.C
                  But yes, you can O ring it still, but that would take a trip to the machine shop. Cut ring is faster/easier.
                    I checked my ARP torque after ~20 heat cycles and they had lost a little torque. There is a lot at play when you have that many items stacking up when cold, then subjecting them to multiple heat cycles. I suspect some internal stresses exist when you first mount the cylinder head due to very small misalignments and fasteners causing preloads in different items. After some heat cycling these internal stresses relocate or cause the component to relax and causes a slight torque loss. Just a hypothesis.
                    They dont need to be babysat, but checking them after some heat cycles is a requirement for me.
                      I have a call into them. Going to ask if they have different thicknesses IF I have to resurface the head.
                        Give them a call! But they have different thicknesses for sure, and you have to resurface the head for sure as well.
                          I also agree with snap. Maybe you don't need to re torque on most applications, but I'd say this is one of those applications where it's always good to take the extra precaution.
                              hut hut hike!
                              1alligator2alligator3alligator4alligator5alligator
                                Do you also have to take your turbo off to get your valve cover off?
                                I suppose if you are taking your head off it is coming off anyway.
                                  Camshaft time.. oh goodness
                                    Don'tbreakdontbreakdonrbreakdontbreak
                                      None broken. No tools used except for an 11mm and a Cresent Wrench.
                                        God damn that harbor freight life is everywhere!
                                          The head gasket replacement journey.
                                          Keeping organized.
                                          Too much wear?
                                          I can feel this one with my fingernail.
                                          Now I just need to disconnect my downpipe and remove the ARP head bolts and see the carnage.
