  4. Doormans e30 325e
Doormans e30 325e
115 Posts 14 Posters 0 Views 1 Watching
    Doorman
    CYoung said:
    What's he asking for the wheel?? He's gotta make a profit to run his storefront.
    I'm just playin.
    It's a member here.
        Doorman
        Busy in Doormans world lately.
        Got the trans fluid changed last weekend.
        Sport steering wheel being delivered (in person.....no I WONT give you a reach around) late this week.
        Did some wet sanding on the hood today.
        Tapatalk isn't cooperating!!
        I'll upload pics in a bit.
          Doorman
          Let's try to upload again....
          Entire leading half of the good looked like this.
          Decided to only do the center section to learn
          1000, 1500, 2000, 3000 grit wet
          Huge difference after hitting it with my Harbor Freight DA and some Meg's ultimate compound.
          Did the drivers side after my last post
            Very nice!
            I cant remember, did you have any plans for engine work?
              Doorman
              Very nice!I cant remember, did you have any plans for engine work?
              Thanks!
              Nothing in particular.
              Timing belt was done feb/2013
              M50 swap does look appealing though.
              On the hunt for rims/tires, shocks, struts, springs and a few odds and ends.
              Houndstooth (black/grey) fabric would be my "unicorn"!!
                24v!
                Do it. I have an m50 now. Currently tearing apart an s50. If you have a healthy m20 just boost it.
                If not put, a sledge hammer through the intake manifold
                  Doorman
                  24v!
                  M/S50 will be a bit down the road.
                  Picked up all the paperwork and some extra keys for the car yesterday. Some paperwork dates back to 1989!! PO spent more in 2013 in repairs to the car then I did buying the car from him. Looks like the odometer has been broke since 2007......500,000 miles could be a reality for this car.
                  Worked on wetsanding/paint correction on the trunk. The paint that was used on the passenger side appears to be a bit lighter and not as deep as the original paint.
                  Much better none the less.
                  Couple before shots.
                  ddeb1d19681695954ac49a3fe4c2ad2b.jpgafa5fae9f546e522a8e1a0f6a4b72e4b.jpg42c3daff3861f145ff67f3390b46cc26.jpg
                  Some afters.
                  The line on the trunk is visible but you can't really feel it.
                    Please dont do an M50
                      Doorman
                      Nothing is set in stone.
                      V8 builds I've been reading do seem appealing.....
                        Do an s5x
                        And use the m20 as a boat anchor.
                          Doorman
                          Present time!!
                          Got home early today and USPS knocked on the door about ten minutes later.
                          Parts deliveries make a man feel all warm and giddy inside.......outside of normal middle aged gas, incontinence, etc.
                          Gonna give the old girl a well needed wash in the driveway and then install shiny parts!!
                          New wiper arms
                          Cowl grilles
                          Washer fluid pump
                          Washer fluid pump grommet.
                            Doorman
                            Stripped the rear end down for new wheel bearings.
                            Harbor Freight wheel bearing kit worked perfectly.
                            Couple issues/questions
                            Passenger side came off flawlessly.
                            Sometime in the past the drivers side half shaft was replaced.
                            All 6 bolts on the diff were stripped......probably used a 5/16 Allen instead of an 8mm to install the shaft. Bought an Irwin stripped bolt removal set. Well worth the $30!!
                            Drivers side splines are a bit rough......took quite a bit of work to push it outta the hub.
                            Any opinions on rebuilt/rebooting shafts?
                            I've done some looking around and most info points to auto parts store shafts being crap.
                              Doorman
                              Presents!!
                              New grilles
                              Used kidneys
                              All new hardware for both
                              PS reservoir
                              2 new hoses and fitting, washers, clamps, etc
                              2 shirts as well!!
                              All e30 owners know this sight or will soon!!
                              Ordered from BluntTech
                              2 wheel bearing "kits"
                              New lug bolts
                              6 new bolts for the axle-diff
                              Diff bushing
                              2 new CV axles ordered from AutoZone.
                              I called a few shops around Chicago and nobody rebuilds anymore. The guys I talked to said the quality of the axles from the parts stores has gotten better over the years and that's where they get theirs.
                                Lot's of good stuff!  I have used Oreillys axles, one is going on 30k on my Maxima with no issues.  Now I need to replace the other one, it has been clicking all winter, I hate working on the DD...
                                  Doorman
                                  All the parts are finally installed!!
                                  Finished up the power steering reservoir and hoses earlier today.
                                  I still have a bit if "whine" from I think the rear end. A bit of research says it could be the diff.
                                  The car does have over 300,000 miles on her.
                                  Any other guesses?
                                    I'd say flush the diff, probably time for it anyways.
                                      Doorman
                                      Did the diff and trans fluid about a month ago. Neither one looked too bad.
                                        Doorman
                                        Finally a worthy update!!!
                                        After much patience.......finally got ahold of a houndstooth seat!
                                        A member on R3V (iso_hi) had a comfort passenger seat in black/grey houndstooth for sale. After a few PMs he agreed to just send me the fabric. It's been sitting in my garage since mid May, but with work/family I haven't had time until recently to pull the seat. I'm really happy with how it turned out.
                                        c489f79dced282c66638655a792ebda4.jpg68003b847a467a453c8392b3906b2a31.jpg702e5722f652308617d39c75953a566e.jpg0c50c63ba9314bb28e1b85bc876fcd98.jpg
                                        I'll get some interior shots when the sun is out and the car is outside.
                                        So far the "black car" (families name) has been good to us. A/C blows cold and she's fairly drama free.
                                        She still needs better wheels/tires and a shock/strut/spring overhaul.
                                        Added a 2011 328i xdrive to the stable recently (wife wanted to ditch the mini van....who could blame her) so our bmw stable has grown to three!!!
                                        Part of me wants to unload the e39 touring and the e30 and just get a clean e36/e46 for myself.......wife says no!!
                                        She loves them all!!
                                          That's a great stable and the e30 is looking great!
                                          I've been wanting a daily e39...or a e38...or a working e46 m3...
