  4. Doormans e30 325e
Doormans e30 325e
115 Posts 14 Posters 0 Views 1 Watching
    Doorman
    New drivers side front wheel bearing installed yesterday.
    Not a horrible job. Had to grab a 3' piece of gas pipe from the hardware store for a cheater bar.
    Grabbed some weather tech universal floor mats today, $50 for the set.
    Drained and filled the dif and have the fluid for the tranny next.
    Found a sport steering wheel.....the seller has seen too many episodes of Pawn Stars!!!!
    Should have it all ironed out this week.
      What's he asking for the wheel?? He's gotta make a profit to run his storefront.
        Doorman
        I'm just playin.
        It's a member here.
            Doorman
            Busy in Doormans world lately.
            Got the trans fluid changed last weekend.
            Sport steering wheel being delivered (in person.....no I WONT give you a reach around) late this week.
            Did some wet sanding on the hood today.
            Tapatalk isn't cooperating!!
            I'll upload pics in a bit.
              Doorman
              Let's try to upload again....
              Entire leading half of the good looked like this.
              Decided to only do the center section to learn
              1000, 1500, 2000, 3000 grit wet
              Huge difference after hitting it with my Harbor Freight DA and some Meg's ultimate compound.
              Did the drivers side after my last post
                Very nice!
                I cant remember, did you have any plans for engine work?
                  Doorman
                  Very nice!I cant remember, did you have any plans for engine work?
                  Thanks!
                  Nothing in particular.
                  Timing belt was done feb/2013
                  M50 swap does look appealing though.
                  On the hunt for rims/tires, shocks, struts, springs and a few odds and ends.
                  Houndstooth (black/grey) fabric would be my "unicorn"!!
                    24v!
                    Do it. I have an m50 now. Currently tearing apart an s50. If you have a healthy m20 just boost it.
                    If not put, a sledge hammer through the intake manifold
                      Doorman
                      24v!
                      M/S50 will be a bit down the road.
                      Picked up all the paperwork and some extra keys for the car yesterday. Some paperwork dates back to 1989!! PO spent more in 2013 in repairs to the car then I did buying the car from him. Looks like the odometer has been broke since 2007......500,000 miles could be a reality for this car.
                      Worked on wetsanding/paint correction on the trunk. The paint that was used on the passenger side appears to be a bit lighter and not as deep as the original paint.
                      Much better none the less.
                      Couple before shots.
                      ddeb1d19681695954ac49a3fe4c2ad2b.jpgafa5fae9f546e522a8e1a0f6a4b72e4b.jpg42c3daff3861f145ff67f3390b46cc26.jpg
                      Some afters.
                      The line on the trunk is visible but you can't really feel it.
                        Please dont do an M50
                          Doorman
                          Nothing is set in stone.
                          V8 builds I've been reading do seem appealing.....
                            Do an s5x
                            And use the m20 as a boat anchor.
                              Doorman
                              Present time!!
                              Got home early today and USPS knocked on the door about ten minutes later.
                              Parts deliveries make a man feel all warm and giddy inside.......outside of normal middle aged gas, incontinence, etc.
                              Gonna give the old girl a well needed wash in the driveway and then install shiny parts!!
                              New wiper arms
                              Cowl grilles
                              Washer fluid pump
                              Washer fluid pump grommet.
                                Doorman
                                Stripped the rear end down for new wheel bearings.
                                Harbor Freight wheel bearing kit worked perfectly.
                                Couple issues/questions
                                Passenger side came off flawlessly.
                                Sometime in the past the drivers side half shaft was replaced.
                                All 6 bolts on the diff were stripped......probably used a 5/16 Allen instead of an 8mm to install the shaft. Bought an Irwin stripped bolt removal set. Well worth the $30!!
                                Drivers side splines are a bit rough......took quite a bit of work to push it outta the hub.
                                Any opinions on rebuilt/rebooting shafts?
                                I've done some looking around and most info points to auto parts store shafts being crap.
                                  Doorman
                                  Presents!!
                                  New grilles
                                  Used kidneys
                                  All new hardware for both
                                  PS reservoir
                                  2 new hoses and fitting, washers, clamps, etc
                                  2 shirts as well!!
                                  All e30 owners know this sight or will soon!!
                                  Ordered from BluntTech
                                  2 wheel bearing "kits"
                                  New lug bolts
                                  6 new bolts for the axle-diff
                                  Diff bushing
                                  2 new CV axles ordered from AutoZone.
                                  I called a few shops around Chicago and nobody rebuilds anymore. The guys I talked to said the quality of the axles from the parts stores has gotten better over the years and that's where they get theirs.
                                    Lot's of good stuff!  I have used Oreillys axles, one is going on 30k on my Maxima with no issues.  Now I need to replace the other one, it has been clicking all winter, I hate working on the DD...
                                      Doorman
                                      All the parts are finally installed!!
                                      Finished up the power steering reservoir and hoses earlier today.
                                      I still have a bit if "whine" from I think the rear end. A bit of research says it could be the diff.
                                      The car does have over 300,000 miles on her.
                                      Any other guesses?
                                        I'd say flush the diff, probably time for it anyways.
                                          Doorman
                                          Did the diff and trans fluid about a month ago. Neither one looked too bad.
