  4. Doormans e30 325e
Doormans e30 325e
115 Posts 14 Posters 2.0k Views 1 Watching
    Doorman
    Lots of patience with an open end wrench if I recall correctly.
    Did you torque it to spec or just tighten the shit out of it?
      The drivers side wasnt an issue but on the passenger side I had two different 22mm wrenches and took turns with each one/whichever one fit without interfering. Turn it a few degrees, then use the other one. Quite tedious
        No torque wrench, just the calibrated elbow, It isn't super critical like headbolts.
          Doorman
          That was the worst one to get off.
          I'll take both of your guys advise and crank them down.
          • andyhundleyA
            andyhundleyA
            andyhundley
            I cut a 22mm wrench in half and used a another box wrench and piggy backed it. Those bolts are never fun!
              Doorman
              andyhundley said:
              I cut a 22mm wrench in half and used a another box wrench and piggy backed it. Those bolts are never fun!Sent from my iPhone using Tapatalk
              Craftsman 22" wrench was all I had that fit.
              Bought a ratchet wrench.....too big a head.
              Everything in the front feels nice and tight after a test drive. Gonna get an alignment this week.
              I knew I had a bad wheel bearing.....
              Drivers side felt like gravel on disassembly.
              After all the new bushings it's louder then ever!!
              Gonna grab one this week.
                Doorman
                New drivers side front wheel bearing installed yesterday.
                Not a horrible job. Had to grab a 3' piece of gas pipe from the hardware store for a cheater bar.
                Grabbed some weather tech universal floor mats today, $50 for the set.
                Drained and filled the dif and have the fluid for the tranny next.
                Found a sport steering wheel.....the seller has seen too many episodes of Pawn Stars!!!!
                Should have it all ironed out this week.
                  What's he asking for the wheel?? He's gotta make a profit to run his storefront.
                    Doorman
                    I'm just playin.
                    It's a member here.
                        Doorman
                        Busy in Doormans world lately.
                        Got the trans fluid changed last weekend.
                        Sport steering wheel being delivered (in person.....no I WONT give you a reach around) late this week.
                        Did some wet sanding on the hood today.
                        Tapatalk isn't cooperating!!
                        I'll upload pics in a bit.
                          Doorman
                          Let's try to upload again....
                          Entire leading half of the good looked like this.
                          Decided to only do the center section to learn
                          1000, 1500, 2000, 3000 grit wet
                          Huge difference after hitting it with my Harbor Freight DA and some Meg's ultimate compound.
                          Did the drivers side after my last post
                            Very nice!
                            I cant remember, did you have any plans for engine work?
                              Doorman
                              Very nice!I cant remember, did you have any plans for engine work?
                              Thanks!
                              Nothing in particular.
                              Timing belt was done feb/2013
                              M50 swap does look appealing though.
                              On the hunt for rims/tires, shocks, struts, springs and a few odds and ends.
                              Houndstooth (black/grey) fabric would be my "unicorn"!!
                                24v!
                                Do it. I have an m50 now. Currently tearing apart an s50. If you have a healthy m20 just boost it.
                                If not put, a sledge hammer through the intake manifold
                                  Doorman
                                  24v!
                                  M/S50 will be a bit down the road.
                                  Picked up all the paperwork and some extra keys for the car yesterday. Some paperwork dates back to 1989!! PO spent more in 2013 in repairs to the car then I did buying the car from him. Looks like the odometer has been broke since 2007......500,000 miles could be a reality for this car.
                                  Worked on wetsanding/paint correction on the trunk. The paint that was used on the passenger side appears to be a bit lighter and not as deep as the original paint.
                                  Much better none the less.
                                  Couple before shots.
                                  ddeb1d19681695954ac49a3fe4c2ad2b.jpgafa5fae9f546e522a8e1a0f6a4b72e4b.jpg42c3daff3861f145ff67f3390b46cc26.jpg
                                  Some afters.
                                  The line on the trunk is visible but you can't really feel it.
                                    Please dont do an M50
                                      Doorman
                                      Nothing is set in stone.
                                      V8 builds I've been reading do seem appealing.....
                                        Do an s5x
                                        And use the m20 as a boat anchor.
                                          Doorman
                                          Present time!!
                                          Got home early today and USPS knocked on the door about ten minutes later.
                                          Parts deliveries make a man feel all warm and giddy inside.......outside of normal middle aged gas, incontinence, etc.
                                          Gonna give the old girl a well needed wash in the driveway and then install shiny parts!!
                                          New wiper arms
                                          Cowl grilles
                                          Washer fluid pump
                                          Washer fluid pump grommet.
