  4. Doormans e30 325e
Doormans e30 325e
115 Posts 14 Posters 2.0k Views 1 Watching
    No torque wrench, just the calibrated elbow, It isn't super critical like headbolts.
      Doorman
      The drivers side wasnt an issue but on the passenger side I had two different 22mm wrenches and took turns with each one/whichever one fit without interfering. Turn it a few degrees, then use the other one. Quite tedious
      That was the worst one to get off.
      I'll take both of your guys advise and crank them down.
      • andyhundleyA
        andyhundleyA
        andyhundley
        I cut a 22mm wrench in half and used a another box wrench and piggy backed it. Those bolts are never fun!
          Doorman
          andyhundley said:
          I cut a 22mm wrench in half and used a another box wrench and piggy backed it. Those bolts are never fun!Sent from my iPhone using Tapatalk
          Craftsman 22" wrench was all I had that fit.
          Bought a ratchet wrench.....too big a head.
          Everything in the front feels nice and tight after a test drive. Gonna get an alignment this week.
          I knew I had a bad wheel bearing.....
          Drivers side felt like gravel on disassembly.
          After all the new bushings it's louder then ever!!
          Gonna grab one this week.
            Doorman
            New drivers side front wheel bearing installed yesterday.
            Not a horrible job. Had to grab a 3' piece of gas pipe from the hardware store for a cheater bar.
            Grabbed some weather tech universal floor mats today, $50 for the set.
            Drained and filled the dif and have the fluid for the tranny next.
            Found a sport steering wheel.....the seller has seen too many episodes of Pawn Stars!!!!
            Should have it all ironed out this week.
              What's he asking for the wheel?? He's gotta make a profit to run his storefront.
                Doorman
                I'm just playin.
                It's a member here.
                    Doorman
                    Busy in Doormans world lately.
                    Got the trans fluid changed last weekend.
                    Sport steering wheel being delivered (in person.....no I WONT give you a reach around) late this week.
                    Did some wet sanding on the hood today.
                    Tapatalk isn't cooperating!!
                    I'll upload pics in a bit.
                      Doorman
                      Let's try to upload again....
                      Entire leading half of the good looked like this.
                      Decided to only do the center section to learn
                      1000, 1500, 2000, 3000 grit wet
                      Huge difference after hitting it with my Harbor Freight DA and some Meg's ultimate compound.
                      Did the drivers side after my last post
                        Very nice!
                        I cant remember, did you have any plans for engine work?
                          Doorman
                          Very nice!I cant remember, did you have any plans for engine work?
                          Thanks!
                          Nothing in particular.
                          Timing belt was done feb/2013
                          M50 swap does look appealing though.
                          On the hunt for rims/tires, shocks, struts, springs and a few odds and ends.
                          Houndstooth (black/grey) fabric would be my "unicorn"!!
                            24v!
                            Do it. I have an m50 now. Currently tearing apart an s50. If you have a healthy m20 just boost it.
                            If not put, a sledge hammer through the intake manifold
                              Doorman
                              24v!
                              M/S50 will be a bit down the road.
                              Picked up all the paperwork and some extra keys for the car yesterday. Some paperwork dates back to 1989!! PO spent more in 2013 in repairs to the car then I did buying the car from him. Looks like the odometer has been broke since 2007......500,000 miles could be a reality for this car.
                              Worked on wetsanding/paint correction on the trunk. The paint that was used on the passenger side appears to be a bit lighter and not as deep as the original paint.
                              Much better none the less.
                              Couple before shots.
                              ddeb1d19681695954ac49a3fe4c2ad2b.jpgafa5fae9f546e522a8e1a0f6a4b72e4b.jpg42c3daff3861f145ff67f3390b46cc26.jpg
                              Some afters.
                              The line on the trunk is visible but you can't really feel it.
                                Please dont do an M50
                                  Doorman
                                  Nothing is set in stone.
                                  V8 builds I've been reading do seem appealing.....
                                    Do an s5x
                                    And use the m20 as a boat anchor.
                                      Doorman
                                      Present time!!
                                      Got home early today and USPS knocked on the door about ten minutes later.
                                      Parts deliveries make a man feel all warm and giddy inside.......outside of normal middle aged gas, incontinence, etc.
                                      Gonna give the old girl a well needed wash in the driveway and then install shiny parts!!
                                      New wiper arms
                                      Cowl grilles
                                      Washer fluid pump
                                      Washer fluid pump grommet.
                                        Doorman
                                        Stripped the rear end down for new wheel bearings.
                                        Harbor Freight wheel bearing kit worked perfectly.
                                        Couple issues/questions
                                        Passenger side came off flawlessly.
                                        Sometime in the past the drivers side half shaft was replaced.
                                        All 6 bolts on the diff were stripped......probably used a 5/16 Allen instead of an 8mm to install the shaft. Bought an Irwin stripped bolt removal set. Well worth the $30!!
                                        Drivers side splines are a bit rough......took quite a bit of work to push it outta the hub.
                                        Any opinions on rebuilt/rebooting shafts?
                                        I've done some looking around and most info points to auto parts store shafts being crap.
                                          Doorman
                                          Presents!!
                                          New grilles
                                          Used kidneys
                                          All new hardware for both
                                          PS reservoir
                                          2 new hoses and fitting, washers, clamps, etc
                                          2 shirts as well!!
                                          All e30 owners know this sight or will soon!!
                                          Ordered from BluntTech
                                          2 wheel bearing "kits"
                                          New lug bolts
                                          6 new bolts for the axle-diff
                                          Diff bushing
                                          2 new CV axles ordered from AutoZone.
                                          I called a few shops around Chicago and nobody rebuilds anymore. The guys I talked to said the quality of the axles from the parts stores has gotten better over the years and that's where they get theirs.
