  • e92boostE
    e92boostE
    e92boost
    Holy sh*t you put a lot of work in that thing! Can't wait to see the finish result
    Ben H.
      Dropped my flywheels off yesterday and should be working on the car tomorrow=)
        Ready to move into your storage unit?
          Still haven't found anything
            Stopped by and putzed with the car yesterday.
            Only got the mirrors on, booster delete mounted, and the brake pedal out to modify.
              What's the next step after putting the brake pedal back in?
                I wish I knew=/ There is so much to do that it is hard to figure out where to start.
                • andyhundleyA
                  andyhundleyA
                  andyhundley
                  Dat candy doe!
                  EDIT: I really don't speak that way guys. I hope you don't think any less of me. It was purely for entertainment.
                    Looking good my friend!
                      andyhundley said:
                      Dat candy doe! EDIT: I really don't speak that way guys. I hope you don't think any less of me. It was purely for entertainment. Sent from my iPhone using Tapatalk
                      From what I hear, it'd be pretty hard to think less of you.
                        Started modifying my brake pedal for the booster delete
                        Just need to weld in the shims and get it stripped and powdercoated
                          Finished off the modifications
                          Disassembled my old shifter assembly, did some cleaning, compared current shifter to the z3 shifter, and did some measure to figure out what dssr to orderCAM01329zpswispjflg.jpg
                          I also placed an order with Ireland Engineering for an oilite brass clutch pedal bushings, delrin brake pedal bushings, and brass clutch pivot pin.
                          I also have a z3 rack enroute from Rack Doctor. Should arrive tomorrow
                            The DSSR selector rod length should be identical to the stock selector rod.  Just out of curiosity how long is yours?  Yes bring on the penis jokes.  Mine was a length that rob at UUC had not heard of 184mm center to center on the pins.  He said it should have been 189mm.  He offered to make me a custom one for no extra charge but I just cut 5mm out and tig welded it back together.  Mine is a 2/94 build date.
                              I measured mine and it is about 214.3125mm center to center. The e30 m3 uses a 215mm selector rod so it would be perfect. Not quite sure why mine would be that much different than yours
                                For a grand difference of approximately the thickness of 8 sheets of printer paper. Demand a refund!!!
                                  Different transmission isn't it?  The 6cyl cars have a g250, don't the 4cyl cars have a 240?
                                    Mine was a g250
                                      Ahh, the e30 4cyl cars had a different trans.  So the one that is 215mm-ish is what came out of your car?  Are you getting it from UUC?  Call them up and he should be able to tell you the right one.  Also what the correct selector rod joint on the trans would be.  If you need a new stock size one for some reason I have one that would be great to get out of my garage.
                                        I have actually been talking with UUC and he said they haven't looked into what works on compacts. Haha I have a bend in mine that was to clear the vibration dampener but that had been removed before I got the car. I'll probably get the e30 m3 one and see how it works out. Why do you have a new joint just floating around? Lol
                                          This is a totally BS number lol, two decimal places when measuring in MM is pretty nuts let alone four places!
                                          Pedal is looking good, ya know, as far as brake pedals go!
