    andyhundley said:
    Dat candy doe! EDIT: I really don't speak that way guys. I hope you don't think any less of me. It was purely for entertainment. Sent from my iPhone using Tapatalk
    From what I hear, it'd be pretty hard to think less of you.
      Started modifying my brake pedal for the booster delete
      Just need to weld in the shims and get it stripped and powdercoated
        Finished off the modifications
        Disassembled my old shifter assembly, did some cleaning, compared current shifter to the z3 shifter, and did some measure to figure out what dssr to orderCAM01329zpswispjflg.jpg
        I also placed an order with Ireland Engineering for an oilite brass clutch pedal bushings, delrin brake pedal bushings, and brass clutch pivot pin.
        I also have a z3 rack enroute from Rack Doctor. Should arrive tomorrow
          The DSSR selector rod length should be identical to the stock selector rod.  Just out of curiosity how long is yours?  Yes bring on the penis jokes.  Mine was a length that rob at UUC had not heard of 184mm center to center on the pins.  He said it should have been 189mm.  He offered to make me a custom one for no extra charge but I just cut 5mm out and tig welded it back together.  Mine is a 2/94 build date.
            I measured mine and it is about 214.3125mm center to center. The e30 m3 uses a 215mm selector rod so it would be perfect. Not quite sure why mine would be that much different than yours
              For a grand difference of approximately the thickness of 8 sheets of printer paper. Demand a refund!!!
                Different transmission isn't it?  The 6cyl cars have a g250, don't the 4cyl cars have a 240?
                  Mine was a g250
                    Ahh, the e30 4cyl cars had a different trans.  So the one that is 215mm-ish is what came out of your car?  Are you getting it from UUC?  Call them up and he should be able to tell you the right one.  Also what the correct selector rod joint on the trans would be.  If you need a new stock size one for some reason I have one that would be great to get out of my garage.
                      I have actually been talking with UUC and he said they haven't looked into what works on compacts. Haha I have a bend in mine that was to clear the vibration dampener but that had been removed before I got the car. I'll probably get the e30 m3 one and see how it works out. Why do you have a new joint just floating around? Lol
                        This is a totally BS number lol, two decimal places when measuring in MM is pretty nuts let alone four places!
                        Pedal is looking good, ya know, as far as brake pedals go!
                          It is totally bs. Haha Good catch. I used the handy dandy tape measure and it is almost exactly 8 7/16". Once you convert that over to mm you get the above number=)
                            Its -16.74922 degrees outside right now, this is not the time to be talking about BS numbers
                              I have the joint from when a buddy (BSe46) had a '94 318 sedan and never put it in.  It is the wide kind though which is probably not right for the DSSR.  I have so many parts is ridiculous.  I don't even know what I have is the problem.
                                I would have this style (#12)
                                  Yea that is the narrow late style one, sometime around 94 it switched I think.  I will find a use for it someday lol.
                                      Oooohh , shiny!
                                        "it's just junk mail"
                                          ^haha you like that Snapchat?
