      *DROOL*
        Sweet mother of pearl!
        =D
        nick.e46.330i. said:
        Oh hot damn.
        Came out way better than I could have ever imagined=)
        hahahahahaa
        Wow, its so shiny. Why am I spending all my time on the bottom of my car... Sent from my potato phone
        The bottom of the car is just as important=) I wish I would have stripped it all and redid it before paint...lol
        ClassE said:
        :rolleyes:
        Bassboy3313 said:
        *DROOL*
        I have cotton mouth ever since getting the pictures :P
            My Chasebays overflow arrived on Saturday. Didn't get a chance to take pictures of it until last night
            I just need to source a radiator with an attached filler neck that will fit properly.
            I can't wait to get the car back and start working on it again=)
            • 6670charger6
              6670charger6
              6670charger
              Very nice!
              Appleton, WI
              • e92boostE
                e92boostE
                e92boost
                Holy sh*t you put a lot of work in that thing! Can't wait to see the finish result
                Ben H.
                  Dropped my flywheels off yesterday and should be working on the car tomorrow=)
                    Ready to move into your storage unit?
                      Still haven't found anything
                        Stopped by and putzed with the car yesterday.
                        Only got the mirrors on, booster delete mounted, and the brake pedal out to modify.
                          What's the next step after putting the brake pedal back in?
                            I wish I knew=/ There is so much to do that it is hard to figure out where to start.
                            • andyhundleyA
                              andyhundleyA
                              andyhundley
                              Dat candy doe!
                              EDIT: I really don't speak that way guys. I hope you don't think any less of me. It was purely for entertainment.
                                Looking good my friend!
                                  andyhundley said:
                                  Dat candy doe! EDIT: I really don't speak that way guys. I hope you don't think any less of me. It was purely for entertainment. Sent from my iPhone using Tapatalk
                                  From what I hear, it'd be pretty hard to think less of you.
                                    Started modifying my brake pedal for the booster delete
                                    Just need to weld in the shims and get it stripped and powdercoated
                                      Finished off the modifications
                                      Disassembled my old shifter assembly, did some cleaning, compared current shifter to the z3 shifter, and did some measure to figure out what dssr to orderCAM01329zpswispjflg.jpg
                                      I also placed an order with Ireland Engineering for an oilite brass clutch pedal bushings, delrin brake pedal bushings, and brass clutch pivot pin.
                                      I also have a z3 rack enroute from Rack Doctor. Should arrive tomorrow
                                        The DSSR selector rod length should be identical to the stock selector rod.  Just out of curiosity how long is yours?  Yes bring on the penis jokes.  Mine was a length that rob at UUC had not heard of 184mm center to center on the pins.  He said it should have been 189mm.  He offered to make me a custom one for no extra charge but I just cut 5mm out and tig welded it back together.  Mine is a 2/94 build date.
                                          I measured mine and it is about 214.3125mm center to center. The e30 m3 uses a 215mm selector rod so it would be perfect. Not quite sure why mine would be that much different than yours
