BMW Bushing Puller Tool Needed
An air chisel works really well for removing the outer metal sleeve too. Both of you are upgrading to poly bushings I would assume? They last forever so I see no reason to use OEM=) Also, they are easier to install and they stiffen up the rear a nice amount. I put poly in my compact and my e34 has all poly rear bushings and it feels excellent.
Aren't poly's pretty noisy / harsh?
I'm shooting for 4. I'll know more about my plans once I find the source of some other noises (hopefully tonight).
I don't know what you were thinking but how would next Monday afternoon work for messing around with some bushings?
Did you get this done? I might be able to do them on a hydraulic press for you.
Just to update the thread. I finally carved out some time, and replaced the bushings without removing subframe or the bolts using the techinques in the link I posted earlier.
I didn't take any pics of the process, but it was very straight forward. The only think I'll add to the above is that if you need to replace the plate washers that sit on top of the bushings, you might have to remove the subframe bolts to install them.
So, I've now got a homemade bushing puller thing that I'll happily loan out to whoever for the cost of shipping. It took me about an hour to make the tool, but I was trying to be carefull to get as good a fit as reasonable without going totally anal-rententive.
I'll start a new thread about how I'd like the loaning process to go, and what other tools you'll need to do the job.
It might... My guess it would depend if the bushing is seized onto the bolt / frame of the car. Then again, if it's not a vert, you could probably remove the bolts and then get a saw in there to remove whatever the tool didn't remove.
It's worth a shot... worst case, you'd just pull the subframe anyway.
But... If your subframe bushings are that bad, your trailing arm bushings are probably shot too. You'd probably save time by removing the subframe and doing both jobs at once.
Well borrowed Ben's tool, and no success for me. Puller and heat and all I accomplished was bending the outer metal lip of the subframe bushing. Short of pulling the subframe which I really don't have time or the inclination to do, any suggestions on options? I was able to knock out the long bolt. Thanks.
Thanks. I used a drill and hole saw to clear most of the rubber. Metal center though looks to be stuck to the body. The outer sleeve is stuck to the subframe tube. Car is on jack stands so not enough height to use the sawzall. Any other suggestions ? Starting to see why folks drop the subframe to do this.
Yep. Tapped and inserted a 5/8 bolt into the center piece. Tried to hammer it loose from the top but no luck. Smacked the bolt from the side and got it loose but of course with the aluminum stub broken off on the body. Drilled and dremeled this out. Chisel Dremel and vise grips to work out the sleeve.
Drivers side was a repeat of the same issues. Tried the tool just for laughs with no luck. Back to the drill. Center came out easier but the outer sleeve was worse. Ended up buying a HF air chisel to get it out. Still have some aluminum residue from the core left in the body that I need to ream out. One more trip to the hardware store.
Moral: cool tool but for a Midwest e30 with approx 250k and a lot of winters too much for it
Done. Bottle jack and pipe cap to get the bushings 3/4 in and puller for the last 1/4. Put the bushings in the freezer overnight, heat gunned the tube, coated bushings in dish soap. No more clunk on shifting.
Sending out the tool to Chris this afternoon. Looking forward to a success story!!
