  3. Services Offered/Wanted
  4. BMW Bushing Puller Tool Needed
37 Posts 9 Posters 668 Views 1 Watching
  • BenDemB
    BenDemB
    BenDem
    What a welcome!   You guys are more than welcome to come over and make fun of me while I break my car :)
    I'll PM you both once I figure out timing of stuff, but about a week sounds right. I've got two young kids that dictate when I work on the thing.  FWIW, I'm going to try to do the bushings without dropping the subframe, per the thread I posted above.  Even if you guys are planning on dropping your subframe, the tool should work the same either way.
    • BMWbenB
      BMWbenB
      BMWben
      Are we going to be doing it in 5 minutes too? and please let us know!
      BMWCCA #499464
      • BenDemB
        BenDemB
        BenDem
        I'm shooting for 4.  I'll know more about my plans once I find the source of some other noises (hopefully tonight).
          An air chisel works really well for removing the outer metal sleeve too. Both of you are upgrading to poly bushings I would assume? They last forever so I see no reason to use OEM=) Also, they are easier to install and they stiffen up the rear a nice amount. I put poly in my compact and my e34 has all poly rear bushings and it feels excellent.
          • BenDemB
            BenDemB
            BenDem
            Aren't poly's pretty noisy / harsh?
              Mine aren't harsh and make zero noise. If you lubricate them properly they shouldn't make a peep. Mine are also 75a. That is a hair stiffer than the oem rubber. 90-95a is a good bit stiffer and might bring some road noise
              • BenDemB
                BenDemB
                BenDem
                Good to know.
                Any idea how long the OEM bushings are supposed to last?
                  100,000 miles at best I would say. They are pretty soft too.
                  • BMWbenB
                    BMWbenB
                    BMWben
                    I don't know what you were thinking but how would next Monday afternoon work for messing around with some bushings?
                    BMWCCA #499464
                    • BenDemB
                      BenDemB
                      BenDem
                      Sorry, life kinda got away from me the past few weeks.   I still need to order my bushings.   They should be in middle of next week sometime
                      • BMWbenB
                        BMWbenB
                        BMWben
                        I'm just throwing this out there but if you wanted to or would be able to we could do my bushings Monday evening. I have the bushings in my trunk I just don't have a place to do them in Milwaukee. Just an idea
                        BMWCCA #499464
                          bigjae1976
                          Did you get this done? I might be able to do them on a hydraulic press for you.
                          • BenDemB
                            BenDemB
                            BenDem
                            Just to update the thread.   I finally carved out some time, and replaced the bushings without removing subframe or the bolts using the techinques in the link I posted earlier.
                            I didn't take any pics of the process, but it was very straight forward.  The only think I'll add to the above is that if you need to replace the plate washers that sit on top of the bushings, you might have to remove the subframe bolts to install them.
                            So,  I've now got a homemade bushing puller thing that I'll happily loan out to whoever for the cost of shipping.  It took me about an hour to make the tool, but I was trying to be carefull to get as good a fit as reasonable without going totally anal-rententive.
                            I'll start a new thread about how I'd like the loaning process to go, and what other tools you'll need to do the job.
                              Good to hear it went well! So here's a look at my passenger side rear subframe on the beater. Possible to replace what remains of this bushing without dropping the subframe? I'm not optimistic.
                              • BenDemB
                                BenDemB
                                BenDem
                                It might... My guess it would depend if the bushing is seized onto the bolt / frame of the car.  Then again, if it's not a vert, you could probably remove the bolts and then get a saw in there to remove whatever the tool didn't remove.
                                It's worth a shot... worst case, you'd just pull the subframe anyway.
                                But... If your subframe bushings are that bad, your trailing arm bushings are probably shot too.  You'd probably save time by removing the subframe and doing both jobs at once.
                                  Pm sent about borrowing the tool. Holding on to a little optimism that the bushings will come out with little drama. We'll see.
                                    Well borrowed Ben's tool, and no success for me. Puller and heat and all I accomplished was bending the outer metal lip of the subframe bushing. Short of pulling the subframe which I really don't have time or the inclination to do, any suggestions on options? I was able to knock out the long bolt. Thanks.
                                      It is a pain but I have used a drill bit to destroy as much of the rubber as I could to get the center of the bushing out and then using a sawzall to cut the outer sleeve so that it collapses on itself and falls out.  I did this when I replaced my e36 RTABs.
                                        Thanks. I used a drill and hole saw to clear most of the rubber. Metal center though looks to be stuck to the body. The outer sleeve is stuck to the subframe tube. Car is on jack stands so not enough height to use the sawzall. Any other suggestions ? Starting to see why folks drop the subframe to do this.
                                          The center should just be held in by the rubber.  Could you get a hacksaw in there?  The blades are much smaller.  As soon as the outer sleeve splits it will fall right out.
