  4. 87 535is - getting started
223 Posts 21 Posters 3.7k Views 2 Watching
  • merlM
    merlM
    merl
    It actually will want more fuel at higher RPM. Enough that 24lb/hr injectors are recommended... I can get away with standard injectors (19lb) but you run out at high RPM.
    I will be running Motronic 1.3 with a Miller WAR chip. With the WAR Chip I should be able to dial in enough timing to not knock or ping (I hope).... I also will have an adjustable Cam sprocket to dial in the cam exactly. I know you can get away with a 10:1 motor with a standard ECU, especially if you are running Motronic 1.3 but not with this much work done.
    With the head porting, aggresive cam, and pistons we have to have control on the computer. Miller WAR is plenty for this build. I looked at Megasquirt as well but I was able to order this stuff as a package including the Miller WAR/MAF ... Also there are proven maps for this build for the Miller stuff.
    Never considered the Concours as the body on the car is not much to look at ... not horrible but not great.
      Its plenty good enough,   plus theres free bagels and juice!!!!!!
      • merlM
        merlM
        merl
        LOL !!! ... sold, I'll do it !!
          I want a Miller WAR chip, and their tiny MAF. post pictures of both! :)
          • merlM
            merlM
            merl
            I will when they are received ... I do not have an ETA yet as they have to make the pistons and cam  :cool:
              Why get an 'e' when you can get an 'i'
              /e30 humor
              • merlM
                merlM
                merl
                HA ... didn't even notice that when I posted
                  /e30 humor
                  Don't hating on the ETA  :(  Liking the progress!!
                  • merlM
                    merlM
                    merl
                    Motor completely disconnected except for the transmission. Pull the bolts on the bell housing, pull motor !! Soon !!
                    Still have trim work to do
                    Wiring
                    Diff
                    Vacuum brakes
                    clean engine bay
                    Mount gauges
                    new fuel lines
                    order radiator
                    electric fan
                    mount Hartge spoiler
                    Remove spoiler
                    Have bumpers and spoiler painted
                    and .. oh ya .. build motor.
                    Uggghhh, it's still a long road. Gonna have to put some hours in.
                      This is substantial work though, you are going to be so stoked driving this thing around!  The weather getting nice was definitely a big motivation for me to get my car put back together.
                      • merlM
                        merlM
                        merl
                        Agreed ... I am enjoying every minute of working on the car. So a long road, but enjoyable.
                          The weather rocks. I gotta do a vacuum line revamp. But that can wait. This thing's coming along nicely Merl! :)
                          • merlM
                            merlM
                            merl
                            I don't care what anyone says ... getting the transmission out sucks .... a lot !!
                            I am going to put it in as one unit ... I will make it work. I am not going to put that transmission on after the motor is in .... Ugghhhhh
                              oh definitely not. It was such a breeze to take the engine and trans out in 1 piece and re-install it as 1 piece. You can sit down and do a proper job replacing seals and things when its out of the car too. the next time I need a clutch I will be removing the engine and trans together again.
                                 Drop the front subframe with motor attached to trans= boom.
                                • merlM
                                  merlM
                                  merl
                                  Not enough clearance below the car to pull it off.
                                    Yeah you need a 2 post lift for dropping the subframe. Can you pull an M30 and trans out in 1 piece? It was tight doing that with an M20.
                                    • merlM
                                      merlM
                                      merl
                                      I think it would have made it ... No radiator / AC condensor or aux fan so that gives a bunch of room in the front.
                                        I had to remove the PS pump and radiator to get my engine out, but that was all.
                                        Have you ever weighed your car?
                                          I literally attached my engine hoist to my core support and lifted it right off the subframe/engine combo. Easiest thing I've ever done.
