  4. 87 535is - getting started
223 Posts 21 Posters 3.7k Views 2 Watching
  • merlM
    merlM
    merl
    Ordered ... Pistons, Cam, Miller MAF+War, Cam sprocket !!! wowzers !!
      ohhh YES!  This is frickin awesome!  What company makes those pistons?  it appears that they should match the M30 combustion chamber nicely. What kind of compression increase are you getting and any idea what kind of weight savings these pistons might have over stock? Are you getting the cylinder bores honed + new rings and bearings as well? What duration/make of cam?
      Lots of questions, I know, but this is super exciting stuff!  I will soon find out how much more glorious the induction sounds are with the AFM gone on my car and will report back :D
      • merlM
        merlM
        merl
        These pistons (and cam, cam sprocket) are custom made by Paul Burke with Imagineering
        Compression ratio with these pistons on the M30B35 head is 10.5:1
        Don't know about weight but they are forged
        No boring and prob no honing as the block is a 95,000 mile block
        All new rings and wrist pins. Crank bearings will be determined.
          How much did those pistons set you back? I want to up my compression ratio since I'm not going turbo..
          • merlM
            merlM
            merl
            about $995 for the pistons.
              That's not bad at all, upped the compression that much eh? So, with upping the compression like that, do you have to do anything to the computer?
                It wouldn't require more fuel, it would be using the standard quantity of fuel more efficiently so no changes there, timing tables could likely be advanced everywhere from the conservative factory values except for around a particular 3000-4500 rpm range where BMW SOHC engines can be prone to knock.
                merl,  do you ever attend the Concours BMW car show? You should consider entering your car, I think it would be a huge hit
                • merlM
                  merlM
                  merl
                  It actually will want more fuel at higher RPM. Enough that 24lb/hr injectors are recommended... I can get away with standard injectors (19lb) but you run out at high RPM.
                  I will be running Motronic 1.3 with a Miller WAR chip. With the WAR Chip I should be able to dial in enough timing to not knock or ping (I hope).... I also will have an adjustable Cam sprocket to dial in the cam exactly. I know you can get away with a 10:1 motor with a standard ECU, especially if you are running Motronic 1.3 but not with this much work done.
                  With the head porting, aggresive cam, and pistons we have to have control on the computer. Miller WAR is plenty for this build. I looked at Megasquirt as well but I was able to order this stuff as a package including the Miller WAR/MAF ... Also there are proven maps for this build for the Miller stuff.
                  Never considered the Concours as the body on the car is not much to look at ... not horrible but not great.
                    Its plenty good enough,   plus theres free bagels and juice!!!!!!
                    • merlM
                      merlM
                      merl
                      LOL !!! ... sold, I'll do it !!
                        I want a Miller WAR chip, and their tiny MAF. post pictures of both! :)
                        • merlM
                          merlM
                          merl
                          I will when they are received ... I do not have an ETA yet as they have to make the pistons and cam  :cool:
                            Why get an 'e' when you can get an 'i'
                            /e30 humor
                            • merlM
                              merlM
                              merl
                              HA ... didn't even notice that when I posted
                                /e30 humor
                                Don't hating on the ETA  :(  Liking the progress!!
                                • merlM
                                  merlM
                                  merl
                                  Motor completely disconnected except for the transmission. Pull the bolts on the bell housing, pull motor !! Soon !!
                                  Still have trim work to do
                                  Wiring
                                  Diff
                                  Vacuum brakes
                                  clean engine bay
                                  Mount gauges
                                  new fuel lines
                                  order radiator
                                  electric fan
                                  mount Hartge spoiler
                                  Remove spoiler
                                  Have bumpers and spoiler painted
                                  and .. oh ya .. build motor.
                                  Uggghhh, it's still a long road. Gonna have to put some hours in.
                                    This is substantial work though, you are going to be so stoked driving this thing around!  The weather getting nice was definitely a big motivation for me to get my car put back together.
                                    • merlM
                                      merlM
                                      merl
                                      Agreed ... I am enjoying every minute of working on the car. So a long road, but enjoyable.
                                        The weather rocks. I gotta do a vacuum line revamp. But that can wait. This thing's coming along nicely Merl! :)
                                        • merlM
                                          merlM
                                          merl
                                          I don't care what anyone says ... getting the transmission out sucks .... a lot !!
                                          I am going to put it in as one unit ... I will make it work. I am not going to put that transmission on after the motor is in .... Ugghhhhh
