  4. 87 535is - getting started
223 Posts 21 Posters 3.7k Views 2 Watching
  • StewCrewS
    StewCrewS
    StewCrew
    merl said:
    Happy freakin Birthday to me !! ... It actually is my birthday too ....  :cool:
    Perfect birthday gift to yourself!  This thread has plenty of potential.  I love the look of those tails as well
      Tails? What!
      • StewCrewS
        StewCrewS
        StewCrew
        Brian said:
        Tails? What!
        Referring to the picture he posted of his tails just before the one I quoted, obviously not shown here lol..
          Oh, derp. Yeah, I gotta shadow line my tails sometime soon. Along with my door strips and rain gutter trim. This is lookin good though Merl! I'm excited to see this at a meet.
          • StewCrewS
            StewCrewS
            StewCrew
            Definitely bringing my camera for both of your cars this year.  Especially if you guys park next to each other, photos for daaayyyss!
              My car isn't that photo worthy, but thank you sir. :)
              • merlM
                merlM
                merl
                I'm excited to see it too ... there is still a ton to do.
                Thanks all. I will update more soon.
                • merlM
                  merlM
                  merl
                  Ordered ... Pistons, Cam, Miller MAF+War, Cam sprocket !!! wowzers !!
                    ohhh YES!  This is frickin awesome!  What company makes those pistons?  it appears that they should match the M30 combustion chamber nicely. What kind of compression increase are you getting and any idea what kind of weight savings these pistons might have over stock? Are you getting the cylinder bores honed + new rings and bearings as well? What duration/make of cam?
                    Lots of questions, I know, but this is super exciting stuff!  I will soon find out how much more glorious the induction sounds are with the AFM gone on my car and will report back :D
                    • merlM
                      merlM
                      merl
                      These pistons (and cam, cam sprocket) are custom made by Paul Burke with Imagineering
                      Compression ratio with these pistons on the M30B35 head is 10.5:1
                      Don't know about weight but they are forged
                      No boring and prob no honing as the block is a 95,000 mile block
                      All new rings and wrist pins. Crank bearings will be determined.
                        How much did those pistons set you back? I want to up my compression ratio since I'm not going turbo..
                        • merlM
                          merlM
                          merl
                          about $995 for the pistons.
                            That's not bad at all, upped the compression that much eh? So, with upping the compression like that, do you have to do anything to the computer?
                              It wouldn't require more fuel, it would be using the standard quantity of fuel more efficiently so no changes there, timing tables could likely be advanced everywhere from the conservative factory values except for around a particular 3000-4500 rpm range where BMW SOHC engines can be prone to knock.
                              merl,  do you ever attend the Concours BMW car show? You should consider entering your car, I think it would be a huge hit
                              • merlM
                                merlM
                                merl
                                It actually will want more fuel at higher RPM. Enough that 24lb/hr injectors are recommended... I can get away with standard injectors (19lb) but you run out at high RPM.
                                I will be running Motronic 1.3 with a Miller WAR chip. With the WAR Chip I should be able to dial in enough timing to not knock or ping (I hope).... I also will have an adjustable Cam sprocket to dial in the cam exactly. I know you can get away with a 10:1 motor with a standard ECU, especially if you are running Motronic 1.3 but not with this much work done.
                                With the head porting, aggresive cam, and pistons we have to have control on the computer. Miller WAR is plenty for this build. I looked at Megasquirt as well but I was able to order this stuff as a package including the Miller WAR/MAF ... Also there are proven maps for this build for the Miller stuff.
                                Never considered the Concours as the body on the car is not much to look at ... not horrible but not great.
                                  Its plenty good enough,   plus theres free bagels and juice!!!!!!
                                  • merlM
                                    merlM
                                    merl
                                    LOL !!! ... sold, I'll do it !!
                                      I want a Miller WAR chip, and their tiny MAF. post pictures of both! :)
                                      • merlM
                                        merlM
                                        merl
                                        I will when they are received ... I do not have an ETA yet as they have to make the pistons and cam  :cool:
                                          Why get an 'e' when you can get an 'i'
                                          /e30 humor
