  4. E21 project thread
E21 project thread
    Hey guys! It definitely has been awhile since I have posted updates on the e21 project. If you don’t remember my intro thread that I updated every so often, you can check it out here …
    http://www.wibimmers.com/board/showthread.php?423-Dd-e21
    Recently she has had the title of Daily Driver taken away from her by a 2013 Volkswagen Jetta. Gotta keep it in the family. :P Haha!! I leased it for dirt cheap, so I didn’t have to drive the e21 in the winter which has turned out great. So, the e21 has been parked next to the garage inside a fully enclosed car canopy to get some work done.
    I installed a methanol injection system since the last time I posted as well as a small block chevy aluminum radiator for better cooling. The meth injection feeds right from the washer fluid reservoir. The red led in the gauge cluster is tied to a fluid level sensor in the reservoir to warn me when its almost empty. The green led is wired to a pressure switch that feeds off the boost line. When the switch hits a specified psi level (5 psi on my setup) it will send a signal to the pump to run which in turn illuminates the green led to let me know its on.
    Posted Image
    Posted Image
    Posted Image
    I also have been collecting parts for work that will be done such as EDIS-4 parts from an escort to convert to electronic ignition
    Posted Image
    s14 oil filter housing tapped for oil supply to turbo (so I can get rid of this stupid sandwich plate), ARP head studs, and an e12 throttle body for more air flow.
    This winter I plan on getting quite a bit done on her for preparations for a super fun spring/summer this year. Right now I have been focusing on the rear-end stuff which includes, subframe, trailing arms, sway bar, bushings, etc and rebuilding a spare head I have.
    I got the head cleaned, decked, and had a valve job done on it from C&S Performance in Butler. They did a fantastic job. I then deep cleaned all the internal parts and put it all back together. Unfortunately I don’t have a pic of the head done. Ill add it later.
    Posted Image
    I picked up a spare rear end from forum member kyletime666’s 323i e21. These euro models came with rear disc brakes, which is what I mainly got it for to replace my awful drum setup.
    Posted Image
    Posted Image
    I took the setup over to Snap Understeer’s place to prep it all for POR-15 and paint. First thing I did was wirebrush everything down as much as possible to get heavy crap knocked off and such. After that was the degreaser stage and finally the metal acid-etch stage.
    Posted Image
    Once all dry, it was time for the POR-15.
    Posted Image
    Posted Image
    I decided to go with a beige/copper/black color scheme for the car. I will eventually repaint the car with the same BMW safari beige color, so everything else gets painted. After the two coats of POR-15 dried completely, I went ahead and put primer down on everything. With that said, I give to you, COPPER REAR-END!!!! I think it turned out pretty badass!! :D
    http://i144.photobucket.com/albums/r175/bassboy3313/7b31582f3cf6_af6b3f1d-587a-4aff-804f-4dc1b671101eth450tw610.jpg
    http://i144.photobucket.com/albums/r175/bassboy3313/79c800c4dc1e_00eaeb2f-30a2-4db4-a272-2f210d1c600bth450tw610.jpg
    I went ahead and bought all new poly urethane bushings for the rear-end. They look amazing in my opinion. I know some of you won’t like the color choice, but I strive to be different … WAY different. :P These include:
    subframe bushings
    trailing arm bushings
    sway bar bushings
    different hanger bushings
    and I also swapped my previously ordered steering rack bushings for the newly designed ones in yellow of course.
    http://i144.photobucket.com/albums/r175/bassboy3313/IMG_5571.jpg
    The trailing arm bushings were kind of a bear to get it. Once those were finally done, I bolts up the subframe bushings and viola, one step closer to install.
    http://i144.photobucket.com/albums/r175/bassboy3313/fcb29df04aa9_8f3a4dbf-0949-417f-b696-f800ed8ad468th450tw610.jpg
    Tomorrow I should have the diff bolted to the subframe and the sway bar all painted and bolted on with the new bushings. After that, it’s onto the brake setup with parts I have already and then it will all be installed back on the car.
      Sometimes I felt like I enjoy taking rides in this car more than driving my own. Theres something charming about an e21 brought back from the edge of death which is now running a turbo with K-jet and operates by magic.
      This car isn't being built to a specific crowd pleasing formula that is proven to work, like an E30 with Style 5's, mtech 2 bodywork, shadowline and just the right stance. And because its so different, it is awesome!
        Different is good! I approve :) That copper paint is really cool and those yellow bushings are too! Will be fun to look under the car and see it in person.
          .............oh, and
          Posted Image
          you. me. this friday night on Ryan...'s front lawn.
            UPDATE:
            So since the last post, I have gotten a little more done, but not as much as I hoped. Been pretty busy and more important things came up. The rear subframe assembly has been completed to the point where the brakes and reman axles can now be installed once I pick those up. The LSD has been painted and installed along with the sway bar and bushings.
            Posted Image
            Before installing the subframe assembly back on the car, I wanted to clean up the underbody of the car first. Surprisingly, for a 30 year old Wisconsin car, there wasn’t much rust at all. I was surprised for sure. Here are the only spots of rust I found.
            Posted Image
            Posted Image
            I also removed the fuel parts back there since they were a little rusty and the brackets were broken. I am going to be using a spare set of brackets for the fuel stuff as well as a spare accumulator that is in better condition.
            Posted Image
            After a little wire brushing, metal acid etching, and some por-15 this is what it looks like. Just got to underbody coat it all and its ready for the subframe assembly.
            Posted Image
            Posted Image
            Posted Image
            I tend to jump around when doing this many projects at once. So, along with working on the stuff already posted I also managed to removed the valve cover of the engine and give it a new paint job. Its not the best, but it will do for now. Can always sand blast it back down later if I wanted. Im not worried about it.
            Posted Image
            I also got the trigger wheel/pulley setup done for the megajolt install as well.
            before
            Posted Image
            and after some lathe work and grinding
            Posted Image
            That’s it for now. Will be a slow process, but completion will be reached by late spring/early summer at latest. I will keep updating as I go, so feel free to keep checking in. Thanks guys!!
              Well, much hasn’t really happened lately since I have been busy and also am dealing with a personal hardship. I finally got myself up and motivated to go out and do something today, but not much unfortunately.
              I finished por-15’ing and undercoating things under the rear as well as reinstalled the fuel parts and brackets back up there. I went ahead and replaced the fuel hose that went from the tank sender to the external pump as well since it was in bad condition. Sorry I never took pics of that. I am waiting to install the subframe since I want to replace the ebrake cables and remove driveshaft so I can replace the shifter plate and necessary parts too.
              Like I mentioned I tend to jump around since I have quite a few projects going on at the same time. I went ahead and removed the rear bumper since I will be putting on the euro bumpers I received a couple weeks back. Still haven’t gotten those fully out of the box to take pics of yet. The bumper shocks sure were rusty and left piles of rust dust inside the rails that will need to be vacuumed out.
              Posted Image
              Bumper removed and time to clean that surface rust up and por-15 it all.
              Posted Image
              I also received my front euro bumper bracket adapters this week so I decided to powdercoat those as well as the rear adapters I made.
              Rear adapters
              Posted Image
              Posted Image
              Posted Image
              Front adapters
              Posted Image
              Posted Image
              Posted Image
              That was pretty much it for today. Slow but steady I think. Hopefully things will start picking up, but who knows. Thanks for looking!
                You and Jake are the only ones getting work done around here (posting pics for proof at least :P )
                And you forgot to mention you bought some Bilstein sports for the front!
                With those euro bumpers you really do have just about every rare-ish/desirable E21 part for your car now.
                  Lookin good man! :)
                    Thanks guys. And yes you are right, I did in fact buy front billy sports the other day. Hopefully they work as good as the guy says they do. Then all I need are some billy sports for the rear or get the ones I have rebuilt by bilstein. Then I can start mocking up the coilover sleeves.
                      Post pictures of the car!
                        Small Update:
                        I havent touched the car in weeks, but finally got some time, motivation, and good enough weather to do something. I went ahead and removed the shifter plate and all other necessary parts that will be replaced. I now know why my shifter was so sloppy even when in gear.
                        Video of shifter before removal.
                        Posted Image
                        Wish I would have gotten a picture from underneath, oh well tho. I had to do some cutting and grinding with the dremel in order to remove the rear support pieces. The bolt/nut were completely. Also, the PO thought of the bright idea of putting a long bolt all the way through the tunnel and plate with a nut on the underside to hold things steady. How in the hell does one person hold the bolt head in the cab while removing the nut from under the car? I ended up cutting the nut with the dremel until i could loosen it a tad. Then I went into the cab and cut the head of the bolt off. Was a pain in the ass, but got it done eventually. After that the entire assembly could be taken off.
                        Old parts after removal.
                        Posted Image
                        Posted Image
                        Posted Image
                        Here is the new plate vs. the old plate.
                        Posted Image
                        And after dissambling everything and replacing all parts with brand new parts from AutohausAZ except the shifter itself.
                        Posted Image
                        I am waiting for more por-15 to show up before installing everything back on the car. I want to hit the underside of everything with por-15. I will hopefully remember to take a pic of before/after the por-15 like usual. I will also take another video to compare the "slop" from before/after. Hopefully there will be none. *crosses fingers* Thats it for now.
                          Nice vid
                          Its only going to get easier to be motivated as the days get longer and weather gets warmer. BRING IT ON!!!
                            Mine's just as sloppy on the e28, so I'll need to do the same. Keep the updates coming!
                              Thanks guys and certainly will do!!
                              • StewCrewS
                                StewCrewS
                                StewCrew
                                Im loving that copper rear end. Cant say Ive seen that before. This car is going to feel brand new once its all back together. Keep up the work man, its looking great!
                                  Thanks man! I hope its a huge improvement, which I cant see it NOT being. Lol! Your car is coming along outstanding too by the way.
                                    Last weekend I was able to get the shifter assembly finished and installed. I replaced all parts except the shifter itself. Here is the video of the shifter slop after the installation. Still has a bit in gear, which I am a little disappointed about. Anybody have any suggestions on removing the slop completely?
                                    Posted Image
                                    Here it all is installed.
                                    Posted Image
                                    While waiting for the POR-15 to dry underneath the car around the shifter area, I decided to sand down, remove the surface rust, and POR-15 the rear valance. The before picture of the rear valance can be seen in a previous post. Here it is all rust proofed and looking good.
                                    Posted Image
                                    After the POR-15 was all dry, I went ahead and installed my rear euro bumper brackets that made and powdercoated previously. I just need to measure the space for the lower bolt so I can pick up a spacer and they will be installed for good.
                                    Posted Image
                                    Posted Image
                                    With those bolted up, I went ahead and installed the front euro bumper brackets that I powdercoated previously as well. These were simple since they bolted to the stock bumper shock points.
                                    Posted Image
                                    Posted Image
                                    Posted Image
                                    Posted Image
                                    That was pretty much it for last weekend. Will hopefully get some more work done this weekend as well. Just to end it off, here is a shot of the work space I built for the beam for during the winter. Definitely came in handy with a nice propane turbo heater too!
                                    Posted Image
                                    http://i144.photobucket.com/albums/r175/bassboy3313/62af4a92cd18_40457305-3bd8-4591-8665-a4b6aff89562th450tw610_zps6492a073.jpg
                                      Does that tent hold heat pretty well?
                                        It'll hold heat 100x better then just being outside.. Since it has no "porous" sides/top" It'll retain heat better then say a tarp. It's sealed. That and it'll keep you out of the wind= 1000000x better to work in then just out side in general. I've thought about purchasing oone for the E28. but they're like... $200+ for one that you can actually manvure in!
                                          Yeah I've thought about it too, thats why I'm curious :P
